Yokomo B-MAX2 buggy thread
#107
Just a small issue.
Anyone have a problem with the slipper clutch slipping when its fully locked even?
Have checked the diff, and that is fine and set perfectly.
The diff plates and clutch pads have been inspected, and sanded to rough them up a little bit with 600grit paper.
Still, it slips when fully tightened up. Im trying my AE clutch assy when i get home tonite as it looks exactly the same to see if the clutch pads are somehow defective.
Cheers
Cheers
by chance, is the slipper spring caught on the main layshaft somewhere, such that it isn't pressing fully onto the slipper plate?
#109
I fitted up AE clutch pack, and its still doing it.
Will have to take the diff apart and see what happening in there. Im out of ideas. Never had an issue with a slipper clutch before.
Cheers
#111
I took the diff apart, and it seems one diff ring has a groove in it coz i had it too tight to begin with.
Turned it around, and have began cleaning all the week-old lube out. Will finish it tonight after work. I may of had TOO much lube in there, I dont know, ive built over a dozen ball diffs and never had an issue. Ill start fresh tonight, and triple check all my work.
Cheers
#112
Fully compressed.
Cheers
Cheers
#113
Also, I'd highly recommend tyou adjust the diff initially on the tight side (without over tightening it of course). Then get the slipper set... Then loosen the diff gradually untill it starts to slip... it's the only way I know of to learn that sweet spot on a new diff setup...
Just my 0.02$! Hope you get it all sorted!
#115
Anyone run their car on indoor clay track yet.
#116
Naoto Matsukura at the Yatabe Arena maybe?
#117
Is the B-Max4 stabilizer set a direct fit and do you need any other parts that are not included in the kit?
#118
I have no idea what racer53 is... (getting old)... i,d strongly suggest using the kit lubes (or AE greases). Black trhust lube on the thrust, and the clear diff lube on the rings. Just enough so everything is coated. Then break it in.
http://www.rctech.net/forum/electric...er-clutch.html
I have all the right lubes, and grease. Have a look at his tips, seems to be on the money. I have followed it to the tee, and i still cannot get the car to stop slipping no matter how tight the slipper spring is and the diff is nice and tight. I have got it as good as i can get it where it will slip about a foot /half which isnt too bad, but as its pretty much fully tightened, i have trouble making doubles off a corner as i cant build the instant speed necessary to make the jumps.
Is anyone else having same problem? I feel like im failing at this, but ive built so many ball diffs, mostly AE ones, and NEVER NEVER had a slipping clutch when fully tightened. I have set the diff spot on, as per the link above, not too tight, not too loose, so it cant be the diff.
Ive used the Yokomo slipper pads, and now I changed to the AE slipper pads, but still no change. Currently its satisfactory, but i can tell that its not going to be fantastic on race day.
Cheers
