Like Tree2Likes
Old 08-08-2011, 02:25 AM   #91
I rebuilt my diff a while ago according to this and this is the smoothest and most longlived diff i had yet,runs awesome! thanks again!
Azonic is offline   Reply With Quote
Old 08-08-2011, 06:44 AM   #92
racer53's Avatar
This is awesome. I'm installing the TLR kit on my SCB and the diff would have been a mess had I not found this. Thanks for taking the time to do this.
Anytime...Good Luck...
Thanks for the kind words...Good Luck...
Racer53
"Whatever can go wrong, will go wrong"...Murphy's Law...Murphy was an optimist.
/ FT RC10B4 / FT RC10T4 / Driven just about everything else /
/ Mike's Hobby Shop...Carrolton Texas /
"All short course drivers aren't hackers,but all hackers are short course drivers"
racer53 is offline   Reply With Quote
Old 08-09-2011, 06:41 PM   #93
NLpurplelambo43's Avatar
Okay when I was putting my transmission together on my new Factory Team Sc10 and I posted this as a question on another forum:
Okay today I've been putting together the kit, I have gone through most of it along with the transmission (loose screws held on by thread lock). But now when I put the V2 slipper on with the spur, the whole transmission is binding at a point and gets a slight bit looser as the rotation goes through and repeats.
What I thought was first was that the bearing that I had tried to taken the seals off of, didn't quite go as planned as they were plastic, not rubber. I got them off finally on one bearing and sprayed it with Mootor Cleaner and Degreaser along with Moo-Slick. It felt as smooth and even smoother than the other bearing so I thought I was okay, but I didn't want to try the other one (too hard to do).
After a couple tries of taking off the slipper assembly and putting it back together I got it to go a little smoother, but it doesn't move freely enough for me.
Is it possibly that it is the bearing? Is there a trick to the V2 slipper, it is very tricky to get those gold pads on without them flying around.
As soon as I take the slipper assembly apart if gets smoother, weird..... I don't want to put too much stress on my motor....
My Slash transmission moves WAY more freely, so I don't really understand what's going on.
I'm confused.
Do you know what may be going on?
NLpurplelambo43 is offline   Reply With Quote
Old 08-10-2011, 07:46 AM   #94
racer53's Avatar
First thing I would do, is post this in the SC10 thread, as they will know a lot more than I do about this specific car...
But I will try and help as much as I can...
So after reading your post, it sounds like the tranny is free before you put the slipper clutch assembly on, correct???
If so I would imagine it's probably the bottom slipper plate rubbing against the tranny case...It seem like i've heard about other's having that problem a while back...Other than that go back and make sure you assembeled every thing correctly...There is a trick to the slipper pads...When you put the first one on[The one facing the tranny case]Hold the car to the side so gravity holds the pad down on the spur gear, then slip it up the shaft and hold it against the slipper plate...Once it's seated correctly turn the car back over and install the other...This has proven to be the easiset way for me...
Hopefully you figure out your problem, and sorry if I wasn't much help...
Good Luck, Racer53
Old 08-10-2011, 10:11 AM   #95
I figured out what was wrong before I saw your post. It was exactly that, I tried a couple more times and it got way smoother.
Thanks!
I tried the Moo-Slick and it seems as if it is as good and or better than the 50 weight oil, all my bearings are treated with it throughout the car.
The Moo-Tor Cleaner and Degreaser works very well for cleaning up shock oil etc..... Used a lot. I did have a problem with the can, you could only spray the stuff out if you turn the can upside down or on its sides. I emailed Heath and 30 minutes later he replied and told me to send the Paypal invoice and he would have a new can sent out to me. I can keep the other can!
The Cow-Duster is amazing, very strong and feels like an actual air compressor. It's smaller and is heavy as the bigger and taller bottles.
The can is labeled lower than what it is, because he didn't count the fillers and propellants!
That's the best customer support I have EVER dealt with.
I listened to your instructions and built my transmission, the diff sounds soooooo much quieter than many of the racer's SC10s have! Great job!
Old 08-10-2011, 10:51 AM   #96
racer53's Avatar
Cool, I'm glad you figuered the problem out...
Good Luck, Racer53
Old 08-13-2011, 07:43 AM   #97
Asharus's Avatar
Trader Rating: 42 (100%+)
Now that I have some time and have 2 spare ball diffs, I'm gonna rebuild them. What's the best way of cleaning the gunk out of the ball diff gear? I'm having a hell of a time getting the gunk out of the holes where the balls sit.
Angelo Padilla
Team Ballz Racin | PCR Bodies | Island Raceway & Hobby | Gilligan's Raceway
Asharus is offline   Reply With Quote
Old 08-13-2011, 08:17 AM   #98
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
break clean and a tooth brush,air
Jamie W
*Team Tekin*TLR Racing*DE Racing*92 Zero Design*AKA*DDHRC*
20 SMOKE is online now   Reply With Quote
Old 08-13-2011, 08:32 AM   #99
Mac The Knife's Avatar
Trader Rating: 33 (100%+)
pipe cleaner.
The Original SC10 4X4 Clutch Basket
Steve McGeorge
Mac The Knife is offline   Reply With Quote
Old 08-13-2011, 12:42 PM   #100
racer53's Avatar
I use Nitro Force 2...But you could use some rubbing alcohol and pipe cleaner...
Racer53
Old 08-13-2011, 06:34 PM   #101
Asharus's Avatar
thanks for the tips, alcohol + pipe cleaner worked great.
Angelo Padilla
Old 08-13-2011, 07:12 PM   #102
Lojik's Avatar
Originally Posted by D-Rek07 View Post
What will getting the glaze off of the pads do to the performance?
Increase the resistance of the pads making the slipper stronger allowing more power to hit the floor, if they are glazed they will slip too much meaning more power is lost in the slipper. of course if you are running on glazed pads and you have the slipper super tight you may need to loosen your slipper a little when the pads are unglazed or new as the old tightness might be too much.
someone correct me if i'm wrong please, still new to this also.
B4.2ish 21.5T, Speed Passion, Team Zombie, Hitec, J Concepts
B44.2 17.5T, Speed Passion, Team Zombie, J Concepts
Radio: Futaba 4PLS
Club: Keilor Off-Road RC Car Club
Lojik is offline   Reply With Quote
Old 08-14-2011, 06:34 AM   #103
racer53's Avatar
Correct...
Old 08-15-2011, 05:11 PM   #104
racer53's Avatar
Guys I want to thank you for 3000+ views on Part 1...
I have been working on re-doing the videos, after watching them again the other day, and seeing the sound and video quality as well as the MoNoToNe voice
Anyway, the videos should be up in the next couple of days...They will have improved audio and video quality, as well as more personality...I'll let you guys know when they go live...
Thanks guys,
Racer53
Old 08-18-2011, 12:25 PM   #105
racer53's Avatar
