Like Tree4Likes
Old 05-17-2011, 11:40 AM   #31
racer53's Avatar
When adjusting the slipper in say a larger vehicle like the sc10, how much should the front lift? I'm having a hard time gauging if the slipper is too tight or loose watching the front end rise.
You could set it at the factory team setting[3 1/2 turns from when nut is flush with bolt], and then get out on the track and see how it feels...Set it on the straight and gun it, ideally you're looking for it to slip for a foot or so...
Good Luck, Racer53
"Whatever can go wrong, will go wrong"...Murphy's Law...Murphy was an optimist.
/ FT RC10B4 / FT RC10T4 / Driven just about everything else /
/ Mike's Hobby Shop...Carrolton Texas /
"All short course drivers aren't hackers,but all hackers are short course drivers"
racer53 is offline   Reply With Quote
Old 05-17-2011, 04:44 PM   #32
CHIZZLE's Avatar
Trader Rating: 37 (100%+)
Good Luck, Racer53
So, does the slipper bench test not really work for short course trucks?
Chance Renstrom
Repeat after me......"toy cars"
CHIZZLE is offline   Reply With Quote
Old 05-17-2011, 04:59 PM   #33
Briguy's Avatar
Trader Rating: 125 (100%+)
Send a message via Yahoo to Briguy
In my opinion the "bench test" doesn`t work at all period . You need to adjust the slipper to track conditions as your setting will vary depending on traction personal preference . If your track has as much traction as holding your wheels on a bench then it can work
At Your Service Vinyl Works
Royal R/C & Hobby
Leisure Hours Hobby & Raceway
Briguy is offline   Reply With Quote
Old 05-17-2011, 09:03 PM   #34
ohdeeuhm's Avatar
Trader Rating: 18 (100%+)
Awesome tutorial. I've been using gear diffs for a few years and this week will be my first experience with a ball diff. This video has explained quite a bit and now I feel more confident about racing with a ball diff.
Keep up the good work!
www.advrider.com
Riverside RC Raceway -- Petal, MS
Braaaaaaaaaaaap!
ohdeeuhm is offline   Reply With Quote
Old 05-18-2011, 06:55 AM   #35
racer53's Avatar
That's not what I meant...If it where me I would try the "hold both tires and gun it method"...now if that doesn't work, or your having to tighten your slipper down all the way, I would try the factory team setting and see how it does on the track...The method in my paper and videos will work fine, on an SCT I would look for the same 2-3 inches the front tires come up...
Good Luck, Racer53
Old 05-18-2011, 06:56 AM   #36
racer53's Avatar
Thank you...
Good Luck, Racer53
Old 05-18-2011, 08:19 AM   #37
pakk's Avatar
Trader Rating: 79 (100%+)
Do you guys set your slipper the same way between buggy, ST, and SC? Seems like there should be a difference because of different lengths and weights of the vehicles.
I've always set my slipper by "feel." I'd set it it flush then drive around the track and adjust from there.
*Photon* *SC10 4x4*
RCRD
pakk is offline   Reply With Quote
Old 05-18-2011, 10:10 AM   #38
Super Moderator
racer1812's Avatar
Trader Rating: 31 (100%+)
I use it for both buggy and SCT. I feel that it's gets you pretty close to where you need it to be. Some on track final adjusting may be needed. I say it works for both buggy and SCT because it's sort of self adjusting for the vehicle, a buggy being shorter and lighter needs a looser slipper. The slipper setting on a SCT is going to be much tighter to get the same 2 inches of lift than it will be for a buggy. Both lift the same but the slippers are set different. I adjust my slipper VERY little if at all from the 2 inch bench method on my med grip track.
Not the best way to explain it but you should get my point.
Stand for the flag, kneel for the fallen.
Thank you to all of our service men and women!
racer1812 is offline   Reply With Quote
Old 05-18-2011, 11:51 AM   #39
racer53's Avatar
I use it for both buggy and SCT. I feel that it's gets you pretty close to where you need it be. Some on track final adjusting may be needed. I say it works for both buggy and SCT because it's sort of self adjusting for the vehicle, a buggy being shorter and lighter needs a looser slipper. The slipper setting on a SCT is going much tighter to get the same 2 inches of lift than it will be for a buggy. Both lift the same but the slippers are set different. I adjust my slipper VERY little if at all from the 2 inch bench method on my med grip track.
Beat me to it...Excellant explanation
Racer53
Old 05-18-2011, 01:11 PM   #40
mdowney's Avatar
Trader Rating: 21 (100%+)
Great video. Thanks for doing this. Glad it's a sticky.
By the way, sanded my slipper pads and they turned the color of the 500 grit sandpaper. Motor spray didn't seem to do a thing. Problem?
Mike Downey
I try all of the RC kits and usually race at Tacoma RC Raceway
mdowney is offline   Reply With Quote
Old 05-18-2011, 03:15 PM   #41
racer53's Avatar
Thank you...
I haven't had that problem before, as you saw in the video mine came clean...what type of sandpaper and what type of slipper pads where you using???
Just a thought, you could always scrape them with an X-acto knife...
Good Luck, Racer53
Old 05-18-2011, 04:50 PM   #42
mdowney's Avatar
They were AE slipper pads which I had to run for a 17.5 non-ramping class because Kyosho doesn't make a spur gear smaller than 76t. I borrowed the sandpaper from the guy next to me so I don't remember what brand it was. I usually use 3M.
Regardless, I'll be switching back to 13.5 and the Kyosho pads now so I should be good-to-go.
Thanks for your help.
Mike Downey
Old 05-18-2011, 08:36 PM   #43
racer53's Avatar
All-right...Good luck, Racer53
Old 05-18-2011, 11:02 PM   #44
Super Moderator
racer1812's Avatar
An FYI on thrust balls, I'm sure B-Fast makes them but I've seen guys use the carbide DIFF balls from the RC18 vehicles as thrust balls in the 1/10th AE stuff.
Old 05-20-2011, 02:40 PM   #45
Very nice that you got the videos up, this is what i will do to my diff! Thanks alot!
Azonic is offline   Reply With Quote
