"How To Properly Build And Break In a Ball Differential and Slipper Clutch"
#18
What will getting the glaze off of the pads do to the performance?
Also, does setting the slipper clutch that way work for a gear diff too?
Racer53
#19
You can scrape the glaze off the pads with a Xacto knife .
#21
Do you know where I can find out how to do it?
#22
Super Moderator
Trader Rating: 31 (100%+)
I found that sanding the pads is easier than the x-acto method. Use a fine sandpaper, 400-600 grit, they sand easy so you can simply use your finger tips to move the pads on the SP.
#25
Its 2wd, B4.1 rtr
I thought you were asking how to set or break in a gear diff...ugh...sorry.
#27
Great writeup/videos man. Used your method when I rebuilt my diff a couple weeks ago.
That's okay.Thanks
Good Luck, Racer53
#29
Just rebuilt my diff tonight using the methods in your video and its BUTTER. thanks alot for the clean write up.
Good Luck, Racer53
