Like Tree4Likes
Old 11-23-2011, 08:53 AM   #181
kc_nitro_rc's Avatar
Originally Posted by Delawareguy View Post
I should have mentioned that I used the Associated rebuild kit when I did this diff so all of the hardware is new. The diff seemed smooth until I started rotating the tires in opposite directions. Now if feels very gritty with some spots worse than others. You can almost feel it catching in some places.
Maybe you got some debris inside your diff. A lot of times I'll put a paper towel down then work off of that. I'm always looking close to make sure there isn't any lint or tiny particles of who knows what when assembling my diff.
kc_nitro_rc is offline   Reply With Quote
Old 11-24-2011, 05:13 AM   #182
I rebuilt the diff again using new diff balls and it is much smoother. My problem now is that that screw that holds the diff together keeps backing out and making the diff extremely loose. A couple guys at the track suggested that I flip the diff around so that the adjustment screw is on the side opposite the slipper so that the rotation won't cause the screw to back out. I'm going to try it but what do you guys think?
Delawareguy is offline   Reply With Quote
Old 11-26-2011, 06:16 PM   #183
I think you should use a dab of loctite.
Redtoolguy is offline   Reply With Quote
Old 11-27-2011, 02:22 PM   #184
Asharus's Avatar
Trader Rating: 42 (100%+)
Never had this problem.... I would just get a new thrust bolt and nut. Maybe the spring while you're at it.
Angelo Padilla
Team Ballz Racin | PCR Bodies | Island Raceway & Hobby | Gilligan's Raceway
Asharus is offline   Reply With Quote
Old 11-29-2011, 01:09 AM   #185
elikeatts's Avatar
How often should you rebuild a 22 diff?
Serpent America / Desoto Racing / ACE Racing
elikeatts is offline   Reply With Quote
Old 11-29-2011, 11:54 AM   #186
When it starts to feel gritty.
Old 12-02-2011, 09:39 PM   #187
deadmancourt's Avatar
Trader Rating: 11 (92%+)
i have a question about s/c trucks....when setting the slipper and trying to get the front wheels to lift...does the same 3 inch rule apply? i cant seem to get the wheels to lift higher than an inch without the ball diff slipping....
Rob Schneider
Special Thanks To:
S&W Fuel~Agama Usa/HobbyProUsa.com
RcRenew.com and TritonRc.com~Lucky7~Eazyrc.com
Venom-Group~Upgrade-Rc and TrackstarRc.com
deadmancourt is offline   Reply With Quote
Old 12-03-2011, 05:49 PM   #188
Default New here.
Grate video info. It helped me out alot on my 2wd.
But I have a B44 and am kinda having troubles on how to tune the ball diff's and slipper. I haven't really replaced anything in the diff's, but re-oiled the bearings and checked the diff rings. The rings are getting "rings" on them, but the diff's still feel like butter. I'm sure I have to get new everything but I don't want to mess up the new diff's and slipper. I really have no clue on how to make them perfect, or how to tune them.
sorry if this has been spoken of already. Thanks for any help
Muddauber jr is offline   Reply With Quote
Old 12-05-2011, 09:16 AM   #189
Did you set the diff first following this guide? That is crank the nut down all the way on the slipper. Hold the spur gear & right side tire with one hand while trying to turn the left tire with the other.
Once that is done if you try doing the slipper test you will hear the diff grind. Back off the nut about two turns and see what happens.
I hit my throttle hard for just an instant. My front tires hop up about 2". I could pull them up more if I held the throttle longer. But I don't think that is a good way to set the slipper. I'm thinking the general idea is that it must pull the front tires off the ground. If not then it is slipping to much.
Old 12-13-2011, 08:43 PM   #190
Originally Posted by fenx42 View Post
Is it just me or didn't he put the diff in backwards. the screw that you tighten should be on the left (the opposite side as the slipper nut.)
Ive always put mine the opposite side of the slipper.But i do notice people putting it the same side as slipper.I guess its a personal preference type thing.
Losi57 is offline   Reply With Quote
Old 12-14-2011, 09:37 AM   #191
Asharus's Avatar
I put my diff with the screw access on the slipper side, because that's what the manual says to do.
Angelo Padilla
Old 12-15-2011, 10:45 PM   #192
Re-install and adjust ball diff from drivers side
Kyosho RB6/RB5SP2/RT5/USC-R
Norcal-hobbies.com
Castro is offline   Reply With Quote
Old 12-16-2011, 07:06 AM   #193
NLpurplelambo43's Avatar
Getting a pro drivers B-Fast ball diff kit, for one of the presents for Christmas.
Heck yes, and I shall use this once again to build my truck~
WOO
NLpurplelambo43 is offline   Reply With Quote
Old 12-23-2011, 09:12 PM   #194
adawg69's Avatar
Trader Rating: 25 (100%+)
can you massage (sand) the bearings before install???
adawg69 is offline   Reply With Quote
Old 12-23-2011, 11:13 PM   #195
So I just got a B-Fast Pro Drivers kit with the carbide diff balls and the ceramic thrust balls.
I accidentally dropped one of the carbide balls into the carpet, I went over it a bunch with a magnet with no luck.
Now I need to know, could I just use one Team Associated carbide diff ball with the rest being B-Fast carbide diff balls?
I am really pissed off at the moment..
Thanks.
