Like Tree4Likes
Old 11-10-2011, 11:13 PM   #166
why is this thread labeled Important? over half the thread topics here are about cars that don't even have ball diffs and it has much less views/replies than many of the other threads on the first 2 pages.
jasonwipf is offline   Reply With Quote
Old 11-11-2011, 04:28 AM   #167
because a gear diff sticky would be of less use?
jmke is offline   Reply With Quote
Old 11-11-2011, 06:43 AM   #168
Asharus's Avatar
Trader Rating: 42 (100%+)
dude, don't hate. if you're jealous, why don't you create a "how to properly build and break in a gear differential"
lol j/k
Angelo Padilla
Team Ballz Racin | PCR Bodies | Island Raceway & Hobby | Gilligan's Raceway
Asharus is offline   Reply With Quote
Old 11-12-2011, 04:47 PM   #169
Briguy's Avatar
Trader Rating: 125 (100%+)
Send a message via Yahoo to Briguy
Because many people have issues with ball diffs because they don`t know how to correctly build and/or break in a ball diff .
Gear diffs are simple and a monkey couldn`t screw them up .
Don`t like it , don`t read the thread . Simple as that .
At Your Service Vinyl Works
Royal R/C & Hobby
Leisure Hours Hobby & Raceway
Briguy is offline   Reply With Quote
Old 11-12-2011, 07:42 PM   #170
98NYFINESTVETTE's Avatar
I found this thread very useful. If it was not were it is, I probably would not have found it. I thank the person that did all the work for us and also the mod for placing it where it belongs.
You will never please everyone and you will always have people voice negative comments.
SC10 4x4, HPI Baja 5sc, LOSI 5ive T, XO-1, Airplanes & Boats.
We need an Off Road Track in Central Jersey (1/10 & 1/5). When not traveling the country racing in the NMCA, I race off road and on road RC with my son - PRICELESS.
South River Hobby & Bike to the rescue (732) 387-2828.
98NYFINESTVETTE is offline   Reply With Quote
Old 11-14-2011, 09:36 PM   #171
nismomike's Avatar
For the most part, its the RTR's, lower end RC's, and Traxxas that do not come with a ball diff of offer one as an upgrade. Go to any RC forum site and you are gonna see a bunch of questions about ball diffs and shock building tips. Thats why nearly all rc forum sites have them posted as a sticky thread. To help the masses. Great thread fellas.
Thanks to my 2013 sponsors!
*Team Durango~Pro-Line~MIP~RDRP~Futaba~Boca Bearings*
*Hacker Electronics~Muchmore Racing~O’Donnell Racing Fuel~O.S. Engines*
nismomike is offline   Reply With Quote
Old 11-16-2011, 12:03 PM   #172
fenx42's Avatar
Default diff in backwards
Is it just me or didn't he put the diff in backwards. the screw that you tighten should be on the left (the opposite side as the slipper nut.)
-James Williams
Have questions, need help, just ask. I will do my best to help.
fenx42 is offline   Reply With Quote
Old 11-16-2011, 12:04 PM   #173
Asharus's Avatar
it should be on the same side as the slipper nut
Angelo Padilla
Old 11-19-2011, 05:16 PM   #174
I didnt see anything but has anyone installed a ball diff on 2wd slash... Are they suspose to be noisy... Sounds like its slippen ball diff is tight and a quarter turn out on the slipper.....never used a ball diff... So any help would help
slash120 is offline   Reply With Quote
Old 11-21-2011, 12:55 PM   #175
Thanks for the excellent video and write-up!
Anyone know what's in "motor cleaner spray"? Is that specifically for RC model motors? I live in Germany (and I'm a noobie ) and haven't come across that stuff...
LD50 is offline   Reply With Quote
Old 11-21-2011, 01:25 PM   #176
Asharus's Avatar
not sure but its good stuff... it doesnt harm plastic. a friend used standard motor or brake clean spray and it melted some of his plastic...
edit: here's a good discussion on the subject
A NON-RC Motor spray/cleaner?
Angelo Padilla
Old 11-21-2011, 08:37 PM   #177
First off, thank you very much for these videos. I had my first short course race last weekend and had problems with the diff in my SC10. Today I rebuilt it following the instructions in the videos but my diff feels very gritty. The only thing I can think of is that I reused the diff balls for the rebuild. Is it possible that they have gotten damaged and that is what's causing the grittiness? What else could it be? I don't think I tightened the diff too much but would that cause it to feel gritty?
Delawareguy is offline   Reply With Quote
Old 11-22-2011, 07:36 AM   #178
racer53's Avatar
That is a possibility...
The first thing I would do is make sure you have new hardware[such as the balls, rings, and washers]
Then try the process over again, it is possible that the balls have developed flat spots from previous adjustment...
Racer53
Is it screeching, or making crunching, barking noises???
Screeching could be the slipper clutch needing to be tightened more[especially if you have a fast motor]
Crunching or barking is the diff slipping, you'll need to rebuild the diff and make sure it's not slipping in the break in procedure...
Finally, if none of this helps, try taking it to the local hobby shop and see if they can help...Problems with diff's can be hard to diagnose without the seeing the diff in person...
Racer53
"Whatever can go wrong, will go wrong"...Murphy's Law...Murphy was an optimist.
/ FT RC10B4 / FT RC10T4 / Driven just about everything else /
/ Mike's Hobby Shop...Carrolton Texas /
"All short course drivers aren't hackers,but all hackers are short course drivers"
racer53 is offline   Reply With Quote
Old 11-22-2011, 07:40 AM   #179
Racer53
I should have mentioned that I used the Associated rebuild kit when I did this diff so all of the hardware is new. The diff seemed smooth until I started rotating the tires in opposite directions. Now if feels very gritty with some spots worse than others. You can almost feel it catching in some places.
Old 11-23-2011, 07:12 AM   #180
Sprinkler's Avatar
Trader Rating: 28 (100%+)
Send a message via ICQ to Sprinkler
Its just you, your backwards.
John McGinty
Mugen Seiki Racing/ JConcepts/ Tekin/ Absolute Hobbyz/ Advantage Racing Products/ Byron Fuels/ Competetion Heat/ NovaRossi/ Airtronics/ Stickit1racing.com/ Murnan Modified Motors/ M2C Racing
Sprinkler is offline   Reply With Quote
