FT SC10 2wd Tranmsion Binding
Just Finished Building my new FT SC10 and i have problem with the transmison binding, after looking into it i found that my spur gear has a wobble that i have tried very hard to get rid of. I tried losening the transmission case screw to see if i over tightened them i tried to add a thin spacer behind the slipper palte as they were a few things i found after reading, im begining to think i have a tweaked layshaft out of the box but i just wanted to see if anybody else has had this problem thanks for any advice in advanced
Do you have other spurs? Maybe you can try that to see if it fixed that way.
I know you probably already know this, but make sure when building the tranny not to tighten the motor plate screws down all the way. This is often the cause for binding in the tranny.
Super Moderator
Trader Rating: 31 (100%+)
To me, you have 2 questions rolled into one. First does the tranny bind without the slipper installed? If so I would look at the screws, normaly like muck said it's the one that runs through the body mount. Normaly only one screw causes the bind, put them all in loose and snug them down one at a time till you find the one that causes the problem, simply leave that one a little looser than the rest. Using Lostite on all of them of course.
One the spur wobble, most will have some wobble to them, if it's really bad try a diferent spur and see if it's just as bad. I have no spurs that run perfectly true but some are worse than others..a bent top shaft is very very uncommon.
Super Moderator
thanks muck I haven't looked at that, got mine running free but I would like to be able to tighten the screws like hey should be... I'll file the spacer down on mine if I decide to worry about it.
Like Ron Burgundy said, I'd check to see if the bearings are fully seated. I rebuilt my B4.1 tranny last week and the top shaft needed a little help to fully seat the bearing on the motor plate side. Heard a click and she spun as free as ever.
