RPM parts???
RPM parts???
i got the t4 rpm parts the front and rear arms and they went on last night fine.. instead of haveing a normal set screw they have this large button head screw that goes in the same hole as the hinge pin.. the problem is it fell out last night and cause my caster block hinge pin to come out and i could not finish the race
what should i do to replace them or what cause they are not working very well i dont think a set screw will work.. what should i do
i have this same problem. i dont know where to get new screws
ya not sure what to do i was thinking maybe like big set screw i dont known
I've had mine for 2 seasons with no problems, along with 2 other guys that have had for 1 season with no problems. You must of over tightened and stripped it out like it says not to do in the instructions. I suggest to find and oversize screw, if you can't find one short enough just cut it off to the correct length. Chalk it up as a lesson learned.
ya i have more oversized screws i just didnt known if the hole would be stripped out would putting locktite on it at all work??
No loctite doesn't work well with plastic to plastic...try a drop of CA glue...
ok i will try the CA or what about teflan tape would that work or make to thick for the CA glue do i want to put on the screw or in the hole
turns out i dont have any more anything else i could try to put in there to help block the hinge pin from falling out
I want to think on the instructions it said you can use a bigger screw on my Firestorms RPM arms.
Super Moderator
Trader Rating: 31 (100%+)
Pack some Shoe Goo in the hole? People seem to use that crap for everything.
Super Moderator
I think you're going to have a hard time finding a screw like that, bring the arm with you to your LHS and or hardware store. I might just bite the bullet and get a new set of arms and be careful putting the screw in. You did use the GT2 hinge pins correct?....sorry forgot it was the outer pin not inner.
