d8t tekno, which tekin?
alright i will have my converted d8t next week.trying decide on what kv to run. i will run on diff style tracks from large to small and need to run two servos as i will be using a clutch set up. also will run 4-6 cell. going to contact tekin tomorow just wondering what your input would be.
Tech Legend
use this:
http://scriptasylum.com/rc_speed/_top_speed.html
since you already have a vehicle, figure out what you top speed is you are using with the gearing that works. You can then translate that into what you need to do for your D8T for similar speed wise performance on the track. It will at least give you a starting point.
Since you are going to run a clutch setup, Keep in mind you need to have a high enough Kv on the motor so that your clutch bell selections are possible, especially if you are doing 4S. I think the largest I have seen is a 22T from Axial.
Tech Legend
if you have to go with 4S (ROAR rules), go for a battery as close to 6000mah as possible. Back when I did my RC8T conversion, a 6000mah battery pack pretty much guarenteed 15 minutes of runtime regardless of the conditions I ran in including extreme cold temps with very low traction.
