The TLR 22 Guide Thread >
Old 02-28-2012, 04:26 PM
  #31
Fast410's Avatar
Trader Rating: 47 (100%+)
Default 22
Fast410 is offline
Old 03-04-2012, 10:20 PM
  #32
Eli
Eli's Avatar
Trader Rating: 15 (100%+)
Originally Posted by Fast410
muggydude i have a 22 buggy and run on a clay track just recently got my son a dex 210 basically out of the box with little set up . he was driving the dex 410v3 for a couple months he is 12yrs ,he is running faster lap times than the 4 wheel car so i decided to give the car a shot and i could drive it more aggressively than my 22 and it had alot of rear end bite,i have my 22 forsale and do not really want to sell it because you can get parts anywhere unlike durango, any suggestions,running 25-5 up front orange springs 3mm limiters,in the rear yellow springs no rebound in all shocks ,27.5 oil in all four shocks,8.5 trinity with a kenetic esc 78 spur 24 pinion,associated vented clutch set up...thanks in advance
Wrong thread,you should give the car a second chance, it really is a nice car and imo better then the durango. Try asking that question over here- http://www.rctech.net/forum/electric...hread-966.html
Eli is offline
Old 04-07-2012, 07:30 PM
  #33
Default problems with stiff CVAs
Love the build so far, such high quality, The only problem I've had is after I built the CVAs they are a bit stiff. I assume they will break in quickly, but I dont want to run it at all if there's something I can do to fix it. I put grease on it during assembly. Thanks in advance.
velotek1 is offline
Old 04-07-2012, 07:35 PM
  #34
Briguy's Avatar
Trader Rating: 125 (100%+)
They should not be stiff at all . Double check that you built them correctly .
Briguy is offline
Old 04-07-2012, 11:49 PM
  #35
Eli
Eli's Avatar
Did you check for burs?
Eli is offline
Old 07-06-2012, 04:17 AM
  #36
theproffesor's Avatar
Trader Rating: 66 (100%+)
What parts did you use to make those battery strap post, I am wanting to do something just like that. I cant believe Losi hasnt made something. As cool and leading edge as the buggy is, Velcro straps, really?
theproffesor is offline
Old 07-06-2012, 05:27 AM
  #37
Briguy's Avatar
They keep the battery in place don`t they ? Also much faster the having to remove screws .
Briguy is offline
Old 08-04-2012, 12:50 AM
  #38
Rob Phillips's Avatar
One tip that I might add is that you may want to install 3M x 4mm grub screws into the spare holes next to the ball stub on the rear hubs to help to keep the ball studs from ripping out the rear hubs.
Once your steering rack starts to develope a bit of slop you can use a strip of Teflon plumbers tape on the steering rack to take up the slop once it breaks in. Just cut it slightly longer than the rack and apply the tape to face allowing it to wrap around to the sides and bottom edge as well.
Another way to reduce slop in the sterring is to install small pieces of Teflon tape over your ball stud before you snap the ball end on. This will help to tighten up loose ball joints and remove more slop.
Rob Phillips is offline
Old 10-09-2012, 02:29 PM
  #39
kjohnsiii's Avatar
Trader Rating: 55 (100%+)
Great Post! I wish I would have found this thread before I got rid of my first 22b. After reading this I have much more confidence with my second 22b.
kjohnsiii is offline
Old 10-09-2012, 03:15 PM
  #40
tony montana's Avatar
Trader Rating: 76 (100%+)
I agree they do keep the battery in tight. But a battery holder just looks much cleaner looking.
tony montana is offline
Old 10-09-2012, 05:56 PM
  #41
R/C Tech Elite Member
thecman26's Avatar
Trader Rating: 112 (100%+)
Heres one and its pretty sweet!
http://www.diggitydesigns.com/D3_Los...teryStrap.html
I have this one in my 22t!
http://www.diggitydesigns.com/D3_Los...ryStrapV2.html
thecman26 is offline
Old 10-11-2012, 11:56 AM
  #42
HESaves's Avatar
I too have ordered the Battery Strap from Diggity, along with the Front Shock tower...just to see what it will do.
Also, I got this idea from another R/CTechr' and wondering if anybody else has tried this, removing the tray that we can mount the ESC to, to get the ESC lower and on the chassis. I had to modify the rear shock tower a bit to get a better fit.
Anybody here running the Trans Spacers?
Sean
HESaves is offline
Old 10-11-2012, 12:56 PM
  #43
metalracer2's Avatar
Trader Rating: 20 (100%+)
Originally Posted by HESaves
Also, I got this idea from another R/CTechr' and wondering if anybody else has tried this, removing the try that we can mount the ESC to, to get the ESC lower and on the chassis. I had to modify the rear shock tower a bit to get a better fit.
Sean
a local racer in my area mounted a tekin under the tray. he seams to like it.
metalracer2 is offline
Old 10-11-2012, 03:36 PM
  #44
honda man's Avatar
Trader Rating: 2 (75%+)
so does the pro set up really work??
honda man is offline
Old 10-11-2012, 03:59 PM
  #45
Got the 22 built, and the dog bones are really really close to coming out of the slots in the diff outdrives. One actually came out in the first race. Any ideas?
LosiRacer163 is offline
