Old 09-17-2004, 11:51 PM   #1
Angry Newbie Engine question
I am pretty new to the hobby... there isn;t anyone around to help me out with this OS RG of mine in my buggy... I did the break in process and after running for additional 5 tanks I took apart engine... but my engine is a little weird now... when I turn by hand there are two tight spots(one just before piston hits top and the other just after it hits the top) at the very top position it is pretty loose. so it like TIGHT SPOT-LOOSE at the top-Tight spot again... is this normal? or did i assemle my engine wrong? any help will be appreciated.. thanks
jaypark28 is offline   Reply With Quote
Old 09-19-2004, 01:46 AM   #2
Nitro Tech
dino.tw's Avatar
There is a play between con.rod big end and crankpin. The new engine is about 0.01mm~0.02mm.(every mfg. has its tolerance) When the play become bigger and bigger,you will feel it more serious.
All racing engine should keep it under 0.05mm. Engine for practice or just for fun,you can keep it under 0.1mm still ok(don't run too lean). When it become bigger than 0.1mm,its time to maintain it.
dino.tw is offline   Reply With Quote
Newbie Question on Engine Sleeves oggietiu Nitro Off-Road 0 06-30-2008 08:10 PM
Newbie set up question for TC TylerOwenby Rookie Zone 2 05-08-2007 08:39 PM
Newbie question about TC4 va_connoisseur Electric On-Road 4 03-14-2007 10:20 PM
Newbie question kkiel02 Nitro On-Road 10 11-14-2003 12:34 AM
Nitro engine question - newbie question. BloodClod Singapore R/C Racers 6 09-11-2002 09:33 AM
SEO by vBSEO 3.5.0
