C rating, Battery MaH and Punch...
Okay, I am by no means a new racer or new to lipo
BUT
I ask the experts (all of us, we use this stuff each time we hit the track)
WHY
would a 5000 20C (100 amps) pack have more/less punch than a 4000 25C (100 amps)...take your pick of any 2 lipos with same amp ratings.
I can buy into the weight factor, so that aside....
Especially looking for input from racers that have run something similar to this back to back, to see the "feel" difference.
NOT
looking for Brand A is better than Brand B, but more overall knowledge gain...everything else being equal or at least similar.
BUT
WHY
NOT
so i think this is correct. the 1000 mah diff makes up in C thus having the 25c the same... in a nut shell...amps are amps, only thing that could restrict this would be a smaller diameter wire causing drag. the mah rating has some effect on the power. i've noticed running a 5000 compared to a 5600 w/ the same c rating. hope this helps and hope i am right!
Less. Seems C is the dominating factor, since it has an inverse relationship with Internal Resistance. Lower internal resistance equates to more punch. Lower internal resistance results in higher voltage maintained under load, thus more punch.
The max amp thing is not the key here, as I assume you are primarily interested in punch with a stock/spec motor. The amp load being way below the max ratings, is not so important.
This has been my experience both with on track performance, ability to make large jumps and such with stock motors, and reinforced with bench testing.
^^ ya^^
BUT
WHY
NOT
BUT
WHY
NOT
I have run 3200 25C (80 amp) back to back with 3600 20C (72 amp) and could feel a difference in the punch (the 25C packs being years older).
But, I also have some 5400 24C (Older Checkpoints, I think they are 24C) packs that have great punch. Feel as good as my Reedy 35C.
Yes, I mainly run non boosted 17.5, occasionally a 13.5 or VXL motor.
Super Moderator
Trader Rating: 31 (100%+)
