Slash Sway Bar Problem...
Hey guys,
Just got my sway bars and am in the process of trying them out. The rear installation is giving me some problems... here is the link.
http://www.rcninja.com/index.php?rou...oduct_id=63107
Click on additional images... I believe I have it on the rears exactly as it shows. (The set came with no instructions) The movement of the arms now seems to be very restricted and I don't want to put so much force on it that it bends the bar. I can't really get anywhere near bottoming out. Before you ask, the bars are not locked down and rotate freely when not attached to the arms. Ideas?
That's how anti-sway bars work. When you raise one arm, the bar will attempt to lift the other arm... the sway bar WILL twist.
Here is how you can test them... Take the shocks off the truck so that the arms can flop around freely. If you move one arm up and down, does it lift and lower the other arm as well? (not necessarily the same amount, but some). If it does, and the arms move up and down without anything binding, then its installed correctly.
