quick soldering castle esc question >
Old 04-07-2011, 12:34 PM
sm_bailey77's Avatar
Default quick soldering castle esc question
should u remove anymore of the insulation around the battery wires that im going to solder a deans plug too? or is what castle already tinned big enough?
never been to sure of this. need a quick response!
sm_bailey77 is offline
Old 04-07-2011, 01:36 PM
come on guys!
Old 04-07-2011, 01:38 PM
Suspended
Trader Rating: 27 (97%+)
ive never removed more, but i always add more tinning to the existing wire.
ive never had an issue.
FTSC10 is offline
Old 04-07-2011, 02:44 PM
racer53's Avatar
Personally I always cut off what they tinned and i use my own solder...just my 2 cents
racer53 is offline
Old 04-07-2011, 05:16 PM
racer53 Personally I always cut off what they tinned and i use my own solder...just my 2 cents.
+1
Mike1977 is offline
Old 04-07-2011, 06:24 PM
Trader Rating: 16 (100%+)
Use what they have on it and add alittle more
DanielD is offline
Old 04-07-2011, 06:39 PM
I wouldn't add to it because castle uses silver solder, I don't like to mix solder, I'd cut it off and start over
Dragrcr is offline
Old 04-07-2011, 08:25 PM
TailsNeon556's Avatar
/\ this... also don't cut off too much insulation.. 1/8" is all you need.. remember to put heat shrink tubing on before you solder the wires up.. use a real hot soldering iron as well when soldering deans.. be fast.. i also plug the male end into a female connector to help dissipate heat to keep the plug from melting
TailsNeon556 is offline
Old 04-07-2011, 08:32 PM
waggaclint's Avatar
Originally Posted by TailsNeon556
/\use a real hot soldering iron as well when soldering deans.. be fast.. i also plug the male end into a female connector to help dissipate heat to keep the plug from melting
+1 on that
waggaclint is offline
Old 04-07-2011, 09:25 PM
60 watt iron is ok huh?
bowl806 is offline
Old 04-07-2011, 11:06 PM
yea 60 watt should be fine.. i personally use a good 60/40 rosin core solder
Old 04-08-2011, 07:23 AM
i bought 63/37
