WHAT TO DO????
WHAT TO DO????
OK IM JUST GETTIN STARTED WITH THE OUTDOOR SC TRUCKS IM USING BOTH TWO WHEEL AND FOUR WHEEL. WHATS THE RIGHT SIZE MOTOR FOR OUTDOOR TRACKS?IVE ONLY RAN ABOUT 8 OR 9 INDOOR RACES AND THE TRUCKS SEEMED FINE FOR THE INDOOR TRACK,WILL MY MOTORS BE FINE FOR THE LONGER OUTDOOR TRACKS?MY 2/W/D HAS THE MAMBA MAX PRO ESC AND THE NOVAK 17.5 MOTOR.THE 4/W/D IS THE STOCK VELINEON.I UNDERSTAND THAT GEARING CAN BE CHANGED AND IM TRYIN TO LEARN TO WORK THE SETTINGS ON THE MAMBA ESC BUT WILL I BE ABLE TO KEEP UP WITH THE REST OF THE PACK WITH WHAT I GOT?
Depends on what the motor limits are for the classes you want to race. stock velineon in 4X4 should be fine. want more speed just use a 3 cell. once again you will have to check to see if you can run them at the track.
Super Moderator
Trader Rating: 31 (100%+)
Agree, first step is to check the track rules. Until then turn your caps lock off so you stop yelling at us..
They should be fine for outdoor
hey guys thanks for the info im tryin to get all the info about the track ill be running on.(its the one in drums pa)im callin in the mornin.and sorry bout all the screamin.
