Old 04-01-2011, 09:06 PM   #1
cliffhanger's Avatar
Default T4 & SC10 aluminum Rear Hub Carriers
Hi does anyone uses in T4 or SC10 aluminum Rear Hub Carriers?
If so what degree are u using?
Does it worth to shell out 30$ to upgrade?If so what are the benefits to do so?
Thanks for the help
DESC210R ● DEX210 ● DEST210R
Team DE Racing
cliffhanger is offline   Reply With Quote
Old 04-01-2011, 11:55 PM   #2
FantomLeopard's Avatar
Thanks for the help
The zero degree hubs are the ones most used. Benefits? Just more durability.. They have the larger bearing on one side and I have no idea why that would make things better... No reason to buy them if what you have is working for you though.. If you want to try them out just wait until the ones your have break
Always looking to help! PM with questions about anything RC!
- Fantom Ion Motors - Fantom Lipo - Protek Servos - VFS Esc -
FantomLeopard is offline   Reply With Quote
Old 04-02-2011, 12:15 AM   #3
Super Moderator
racer1812's Avatar
Trader Rating: 31 (100%+)
If you don't want to change the toe the can use B44 rear hubs and get the benefits of the larger outer bearing without paying for the aluminium hubs. Rear hubs rarely if ever break.
Just make sure you get all the right parts, as in the B44 crush sleeve.
Stand for the flag, kneel for the fallen.
Thank you to all of our service men and women!
racer1812 is offline   Reply With Quote
Old 04-02-2011, 12:35 AM   #4
BuggyKing's Avatar
Trader Rating: 17 (100%+)
I ran them simply to try diff ballstud and toe-angle adjustments.
Our government is a #$%$ joke, from the head jester on down
RIP Mike M
BuggyKing is offline   Reply With Quote
Old 04-02-2011, 12:40 AM   #5
JFuel11's Avatar
Trader Rating: 152 (100%+)
Default Yes they are worth it.
It would not be the first upgrade I would make... but they are worth it.
1. The larger outter bearing holds up much better as the larger Short Course wheels put alot of stress on the outter bearing and the stock on in the plastic hubs does not last long under these conditions.
2. Having the aluminum hubs are still and help you suspension work better and flex less.
3. Having the tunability of changing the upper section for more adustment holes is great if you find yourself changing tracks and tuning alot for different conditions.
Are they spendy... Yes but I feel they are worth the investment.
Alan Bachman (AKA - Johnny Rocket Fuel)
Help your fellow racers go faster... You will have more competition!!!
Sponsors:
RC America - XRay - Hudy - Maclan Racing - Xpert Servos - Schelle Racing Innovations - AKA Racing Products - DE Racing - Sticky Kicks - Sanwa
JFuel11 is offline   Reply With Quote
Old 04-02-2011, 01:34 PM   #6
so what would the the first upgrade that you would make for sc10 and t4?
and what degree you would by for sc10 rear hubs?
thanks
Team DE Racing
Old 04-02-2011, 01:43 PM   #7
Trader Rating: 49 (100%+)
I ran 1.5 degree on my sc10 and run .5 on the b4.
With the new toe adjustment blocks I would run b44 hubs and not use the aluminum, that's just me.
-Mike B. - TLR22 - Tekin - K.O propo
aradaiel is offline   Reply With Quote
Old 04-02-2011, 06:26 PM   #8
Trader Rating: 25 (100%+)
I think if your racing on a track, getting proper tires would be the first thing to do. Find some setup sheets online and mess around with some suspension settings to find what works with your style of racing. After that, get .5 or 1 degree hubs. I think this was one of the best handling mods I did because it eliminated spinning out when powering through turns. Gear it correctly and youll have a very competitive race truck for not a lot of money. If your still not satisfied, get a mamba 4600 sidewinder combo for $100 and youll have more torque and top end then youll ever want or need.
Good luck and have fun
GaRsNoW is offline   Reply With Quote
Old 11-12-2011, 02:20 PM   #9
What you mean With the new toe adjustment blocks?What part number is it?will they fit ASC9730?
thanks
Team DE Racing
