SC10 hex conversion by Proline
#16
ROAR says 11.42 min and 11.65 max width on the truck. You might be able to fudge the hexes with the different wheels to make it all work with in specs. The Pro-line axle makes it difficult because the grove in the axle for the hinge pin does not allow you to move it in and out. So you are stuck with where the hole is for the hex pin.
#18
#20
Holy S#!* that is confusing.
SC manufactures need to get there stuff straght and make only one wheel off-set work on there design like 1/8 scales do.
#21
If you use the proline conversion kits you must use the Proline Pro Trac zero offset wheels or an equivelant...I think DE makes a set.
To try to use any Blitz or Slash wheels you will need to do a "homemade" mod of some sort....or a mix of the Proline Kit with Narrow hexes from a Kyosho, HPI or STRC...but it will still slightly widen the vehicle.
For now I decided it wasnt worth the effort ...... I would spend $50+ to try reuse my tires and wheels, then possibly end up with something I dont like...I will run the stock style wheels until I have an issue, then I will look it over again.
#22
I tried the OEM bearings...didn't make much of a difference.
#28
Here is some great info from another member posted on RCTech. I guess I need to stop calling them "zero off-set wheels"
10th scale short course wheel compatibility...
Here's what I have measured so far, and a few numbers I got from other places:
wheel_______backspacing
SC104x4____32mm____1-1/4"
SCT-E ______32mm____1-1/4"
Protrac _____32mm____1-1/4"
XXXSCTrear__29mm?___1-1/8"?
Slash/Blitz ___22mm_____7/8"
Slash front ?
Backspacing is the distance from the mounting surface to the inside edge of the wheel.
Mounting a blitz wheel for example, on the back of a XXXSCT adds 1/4" width to each side, 1/2" total.
If you guys have any of these other measurements, let me know.
Slash front ?
