SC10 diff... Gear or ball and why
#31
Facts
Ball diff best features
*superior forward traction
*no diff out when ever accelerating
*easier to drive
*easier to drive
#32
#33
just test & compare lap times between both...
I was with Scott Brown when he tested the difference between the gear & ball when the Sc-10 was not even release yet for sale.
Scotts laps time always improved considerably when using the ball diff..
Me too same thing , way faster , better traction with the ball diff ....
#34
schooling ?
#35
schooling ?
Want more funnies? Most pro's around here have swapped to gear diff's in their SC's (losi, ae and blitz mostly at this point).
#36
Then I dont put any trust into "Scott Brown" no matter who he is. Ball diffs offer NOTHING over a gear diff in terms of reliability or tuning even. Ball diffs are just quicker to adjust. And who knows what he tried for gear fluid weight..........I know that here locally, the hardcore SC10 owners use and prefer the SC10 gear diffs and noone here will recommend the ball units.
Scott is one of Ae's best team drivers ....
and ?
He did test different oils & grease ....
Me too .....
#37
I am not a pro driver by any means but if your gear diff is set up correctly with the proper fluid for your track it has provided me the same lap times as a ball diff. Most of the guys around here and changed back to gear diff just because the reliability and the lack of maintenance needed.
I race 2wd SC as a 3rd class so the less maintenance the better If you are pro or very serious about 2wd SC racing Than the adjustable Ball Diff I am sure would be a better choice. You can tighten or loosen your diff with ease and tune to the correct track conditions. If you are just a club racer having fun than
ask what the guys at your local track prefer for fluid and give the gear diff a shot. Odds are you will never notice a difference.
Just my 2 cents not let the griping resume. LOL
#38
http://www.youtube.com/watch?v=fvSwsQi1dSc
#39
Is everyone aware that gear diffs were common in the early ‘80s cars, both on road and off road, before Schumacher I believe it was introduced the ball diff? Reading this thread I can’t help but wonder why some might think every companies top level 2wd kits (to the best of my knowledge) went to ball diffs fairly quickly. Or which 2wd Worlds, or Nationals even, have been won with gear diffs?
Yep, that is the answer to the original question of why a ball diff. Changing fluid in a gear diff tends to be a compromise between the 2. If you lock it up for acceleration you likely give up some turn in and mid corner speed.
That said, for some tracks, some driver styles, maybe it’s not a big deal. If it works for you then by all means rock on.
#40
I still like the justification of what "the pros use".
Dont buy into stuff that the pros try to sell... I hear this stuff over and over again, only to hear someone a few weeks later talk about their bad decision. Go with what you know. If you dont know; try, ask, or test locally.
Im stuck on a ball diff and i stated the reasons why. I really dont care if i have to tear it down once every 2 months... And i usually race 1-2 times a week.
This thread was Gear or Ball and WHY. Ive stated my WHY!
lol
In all fairness, use what you like, as i do the same.
LETS GO RACE!
lol
LETS GO RACE!
#41
Your driving style and racing surface will determine when and if you "diff out" I have a buddy who likes the gear diff better and runs faster times with it on our small track thing is you can always catch him through a tight corner. Gear diffs can excellerate faster but your wheels better be straight or you will indeed diff out. All the newer team set ups on the associated sites use the ball diff....that in itself should tell you something.
My SC10 is an RTR and I HATED the gear diff.
#43
#44
You don't know who Scott Brown is?? Here is a video of him at the 2011 Reedy invite race with Tebo and Cavaleri and mayfield in the same heat. I would trust his findings over your local "hardcore" sc10 owners....Oh and also he was the 2009 SC national champion.
So you may trust a Pro's level of expertise in setting up a car, but I don't. The only person I trust is myself and my driving style for my vehicle through my own trial and error. And there are alot of older people here locally in this hobby who build and race the "big toys" for a living whose advice I'd take over a hobby pro's advice any day of the week.
That being said, loosening up a ball diff has the exact same effect as putting in lighter weight oil in a gear diff. Tightening up a ball diff is identical to putting in heavier fluid in a gear diff. Ball diffs have one advantage. Quick adjustments. Thats the only good use I see on em. But I have seen ball diffs loosen up a bit in races(like a poorly set slipper clutch) where the car basically loses its effective acceleration power to the point where its slipping to both wheels simultaneously where the car can't effective accelerate anymore. Could have been user error, could have been a stripped adjusting bolt or another worn part. But its something you dont have to worry about with a gear diff.
#45
Still missing the distinction between loaded and un loaded reactions. Oil or grease won’t change that.
Do agree that you have to go with what works for you though.
