ONE WIRE ON BALANCE CONNECTOR BROKE. HELP!!
i have a turnigy lipo battery and one of the wires broke off right near connector. i got the silver bullet connector that the wire goes into out from the white connector but i wanted to know where i can buy new ones because it is mangled and wont stay inside the connector. can i buy them at radio shack? if so what are they called of where can i get them
Something like this?
http://www.amainhobbies.com/product_...ance-Connector
Not sure where to get the actual connector ends, but i believe they are called jst-xh.
Id check out your local hobby shop they may surprise you with what they have in stock.
The actual metal connectors are probly going to be pretty hard to find on their own. You would probly have to buy the whole plug end, just like they do with receiver plugs.
Not sure if other connectors share the same pins? I know the pins are different in say the thunder power style balance plugs.
The JST-XH connectors are made by JST Manufacturing. They appear to sell to the public. You'll have to browse through their site to find the connector you're looking for (and they make a lot).
http://www.jst-mfg.com/
Hope that helps.
Hope that helps.
you could just get the one from A Main and cut the plug off your pack and splice the new one on
you can buy extensions from hobby partz or hobby king and then just splice the correct end on there.
Let me kniow if you have any questions but this is prolly the easiest way. Also the extensions help when charging to allow battery to reach into lipo bag better.
