Turnigy Lipo's...
#16
big squid rc did a test with the turnigy .....http://www.bigsquidrc.com/lipo-batte...-3-4s-edition/
#17
#18
ROAR approved is the way to go since some events only allow those types. Gens lipos are cheap and you won't be turned away after driving to the race.
#20
Might not be able to tell on some tracks but if you race 8 minutes or more on a big track with jumps that you need big power to clear you will notice I am sure. They are not bad and other cells they make might do better also notice though they were 4500 mAh others were 5000+. I have noticed a difference usually its after 5 minutes or longer in a mod 2wd SCT with a 10.5 or 8.5 motor. Not saying you still can't win or do well but there is a difference
#22
Who gives a shit. Maybe in onroad, but in onroad, you have more power than you can transfer to the ground.
I run Turnigy lipo's in my car for more than a year. I've had 1 cell went bad after 14 months of use. I guess that can happen to any brand lipo. And since they are only 50$, you can replace them anytime.
A mate is sponsord by Orion/kyosho and he was driving with the expensive Orion lipo's. Now he's driving with Turnigy, because they are as good as the Orions, but much cheaper.
#23
I dont like that test because they dock it for having less MAH when it is the smallest lipo and they are testing it against lipos with way higher C ratings..
#24
that test is BS.
in order to have a true test, all variables need to be the same, until those variables are the same, the testing is inconclusive, and isnt worth a damn!!
didnt any of you pay attention in science class? take a DEEPER look into those stats...and you find some surprising info that nobody else cares to point out...
thunder power battery under load was 8.31 MAH per second...
checkpoint battery under load was 8.31 MAH per second...
ace battery under load was 8.31 MAH per second...
venom battery under load was 8.31 MAH per second...
turnigy was 8.308 MAH per second...so the battery costing 250 dollars, with a 800mah greater capacity, and a claimed 25c higher rating, can only sustain 2 thousandths of a MAH higher then a 35 dollar battery?
Of course the voltage drops off faster, its a smaller capacity battery!
these tests are so biased its hilarious!
in my SC8E{which is a high amp draw vehicle} i have no issues running until the battery dumps to my LVC cut voltage{3.5 volts per cell} it will hit the triple with the same authority throughout the run.
Until someone shows me that im getting an extra 220 dollars worth of battery, ill stick to my "junk" turnigys!
#26
Thank you for all of your replies...
And to those who suggested I use the search, for one I did try and had quite a few results that had nothing to do with what i searched for,I suggest you try to search sometime and see how it works for you...I have had no succes with it...
#27
that test is BS.
#28
#29
the other funny thing to me is how they never tested a Max Amps at Big Squid.... and they have Max Amps ads on the page.. I wonder why they would not test them.
#30
There was a gap in voltage under just a 30 amp load. Power is Volts * Amps = Watts and when you are talking about punching it less watts =slower in speed and excelleration. Go to a higher draw what do you think you would get? A wider gap in voltage or smaller gap? Taking the mean draw over time well under a cells C rating thats constant will not tell you the whole story unless we are racing on a track where you just pull the trigger once, on a track there usually are sections where braking, soft excelleration and full excelleration are needed and everything inbetween you should be able to tell the difference. I jump around packs much like others might change gearing only thing there is weight also plays a role, but if there is a limit to traction I drop down to a weaker battery if everything else feels right.
