ae ft sc10 setup for ir-cr
Hey everyone, I'm looking for some setup advice for my sc10, I'm currently in Iraq and can't get by the track to see what everybody is running but I will be home soon! I have a novak ballistic 7.5, novak esc. I'm just trying to get a feel for whats popular out there these days. Also I may be thinking this motor might be a bit much? Any advice will be helpful. Thanks!
What type of track surface are you racing on?
It's hard packed clay.
I race at IRCR. I had a FT sc10..
I was running stock springs, 60 front, 40 rear wt oil, 4 degrees rear toe between the blocks and rear hubs I had. Front shocks were middle hole and rears were all the way in.
I think I used kit turnbuckle placement, if I remember correctly.
I like pro-line MC suburbs, soft Jconcepts barcodes and soft AKA wishbones.
A lot of guys are using enduros, just depends on what you like.
Thanks for the info aradaiel, what is a popular turn motor around there for the mod class?
I was running an 8.5 without boost. I'd probably still run around that, maybe a 10.5 or even 13.5 with lotsa boost.
Some guys are running 6.5s
Thankyou sir, there are so many set-ups these days it can get confusing. I'm just try to run with the masses on this one, I appreciate it!
No worries,
There are tons of fast guys out there running them that will be more than happy to help you out with setup and such.
