Old 08-31-2004, 06:20 PM   #1
Default grass
hey guys i need some help on my nitro 2.5 trx motor. i was wondering if grass would make a motor run hot. beucase a few days ago i had it running on the ground and it was fine. and the next day i ran it on the grass with the same settings and it ran a little hot . thx if you can answer that o and also can anyone tell me or find an artical on how to rebuild a s-maxx diff after i put new oil in thx
vengeanceballa is offline   Reply With Quote
Old 08-31-2004, 07:38 PM   #2
corvettecrazy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to corvettecrazy
generally speaking, YES, running in grass will cause a motor to run hotter.
corvettecrazy is offline   Reply With Quote
Old 08-31-2004, 10:20 PM   #3
beetlebz's Avatar
Send a message via AIM to beetlebz
it will cause the clutch to slip a bit. more so on a stadium truck, but to a lesser extent on monsters, yes
beetlebz is offline   Reply With Quote
Old 08-31-2004, 10:22 PM   #4
onnetz's Avatar
also very rarely can you keep the same settings from one day to the next. you can come close, but to keep the same motor temp some minor adjustments should be made.
onnetz is offline   Reply With Quote
Running on Short Grass - how bad for xxx-t? HoaRC Rookie Zone 33 06-26-2008 01:33 PM
vintage grass hopper body hook6905 R/C Items: Wanted to Buy 0 04-27-2008 08:58 PM
NO GRASS TRACK IN USA ???????? RED-LINE M03 Electric Off-Road 28 07-12-2007 05:37 PM
tire for grass joeling Electric Off-Road 4 04-01-2006 08:44 PM
Grass setup for Losi XXX-KE sleek the elite Electric Off-Road 6 04-04-2003 01:06 PM
SEO by vBSEO 3.5.0
