Lipo voltage is 0.0 HELP!!!
Long story short, while soldering a deans plug to a Turnigy 5000 4 cell 14.8v battery, the wires were soldered to the wrong tabs
Didn't notice this until I plugged it in to the ESC. Needless to say it poped and arched at contact. I tried another battery and the esc is fine, motor is fine. I unsoldered the deans, corrected the + - connection and tried to charge it. My charger read the balancing plug was connected but then said no battery. I checked the wires all over, good connections. Checked the voltage at the plug and it reads 0.0, my meter has the sharp tips so I pierced the plactic coating to get to the wires directly, still reads 0.0
Is there any thing else I can try or is this one history?
I would check at the balance plug to see if you get anything at all. Like stated it probably burned a connection inside that links two cells together.
If you take on the task of trying to repair this pack I would use some caution.
Personally I would also ask myself if this pack is worth it.
Super Moderator
Trader Rating: 31 (100%+)
and if you cant fix it you can always make some fireworks out of it . i didnt tell you that though lol. if you do try to repair the pack be veryy careful. lipos are some of the most dangerous batteries in the world.
Super Moderator
No worse than the one under the hood of your car. Short the terminals on that and see what happens. Respect is the key.
Super Moderator
couple long...... not gonna tell ya but it easy..
thats another good valid point fellas, like if the battery is a older battery and you are just seeing if there was a easy way to maybe fixing it. If it was a brand new $150 battery i might look at getting it repaired but still then theres alot involved and in the end it might just be the easier route going with a brand new pack
