HELP! If my tems are high on my motor, would i need to go up turns or down turns?
I've heard from someone that if your motor temps hotter than you want, you can keep the same gearing and go UP on motor turns (more torque maybe)... Is this correct?
yes but would be cheaper to switch gearing
Yeah try the gearing
Hot motor= overgeared
Hot ESC= undergeared
(this means you need to gear down. start by dropping 2 teeth on your pinion)
R/C Tech Elite Member
I have had this issue the past month or two...
Run a 6 minute heat motor comes off at 160... go down one tooth (21)...
Next heat motor comes of at 180... wtf? go up 2 teeth (23)...
Next heat motor comes off at 180... wtf?
Go back to original pinion (22) and its still 160 so that where it stays...
All scenarios the esc stays around 90 degrees... I am lost at a solution so I guess I just run it hot (160)?
Kyosho RT5 22/76
Losi Xcelorin 13.5/ GTB ESC - factory profiles
smooth indoor HIGH traction clay track
This same setup has melted down a NEW murfdogg 13.5 in a week and 2 Ballistic 13.5's so far this year... Nothing is binding, new bearings throughout rear end... Runs like a freak but motors arent cheap! ESPECIALLY the murfdogg...
Kyosho RT5 22/76
Im not really new... racing for 5 years but it's been nitro. Now as for my setup
Hyper 10SC
Turnigy 5200 2S lipo
Comes with an 11 tooth mod 1 pinion
just for something to show the folks this weekend, im either puttin a 8 turn, 21 turn, or 27 tun brushed in it. Since i wont be able to get gears or my brushless until after the weekend, which motor should i run? And whats really gonna be put in it afterwards is a 5700kv brushless from dynamite.
Hyper 10SC
is it a 13.5 spec class?
I could melt down 17.5's all day,
Get 13.5's hot
I run 10.5 cool all year.
My 8.5's come off cold.
If it is an open class it is safer to run a little more than you need & under gear it a touch & turn it down too...
Hyper 10SC
Hyper 10SC
Dont get the dynamite system, you will burn it up in a week. If you cant afford a 550 or a good 540 setup get the Castle Sidewinder SC. Its cheap and has plenty of power for that truck.
Change the driving style/setup or change the motor....
Get 13.5's hot
Get 13.5's hot
So I'm stuck with the 13.5...
I'm running 0 boost (old gtb) losi motors are not adjustable timing wise, have a hakko iron, plenty of solder (use miniatronics 60/40 solder)
Btw the 2 ballistics lasted a day apiece and came off around 260, no saving that thing!
