Old 02-23-2011, 08:52 PM   #1
oplaxboy2's Avatar
Default Sc10 cvd's not running true?
I was wondering if anyone else was having any problems with a factory team sc10's cvd's not running true. If so should I be worried? Do I need to replace them?
oplaxboy2 is offline   Reply With Quote
Old 02-23-2011, 08:58 PM   #2
GizmoJunkie's Avatar
At one time I thought mine were doing that too, but on closer inspection it turns out it is some play between the outdrives and where the dogbone end itself slides into the outdrive.
Both my buggy and SCT do it.
If it is what i think you are talking about anyway.
When you turn a rear wheel do you hear a slight ticking noise that you cant quite locate? It is probly that.
Unless it somehow looks physically bent?
FT B4.1, FT SC10, FT B44; Tekin RS/Savox/D3's
HB D8/D8T - Werks/Buku/Savox
Airtronics
GizmoJunkie is offline   Reply With Quote
Old 02-23-2011, 09:05 PM   #3
oplaxboy2's Avatar
Actually playing with it now you are correct there is a little play. thanks!
