stripped hex screw
Ok, just like sean said, get a dremel and make a slot for a flathead.
If the screw is really too small for it, i have had times where i just grind off the whole top of the screw, and then turn it out with pliers. This calls for a new screw of course lol.
Another option worth a shot is to lay some aluminum foil across the top and see if you can wedge the hex wrench/foil in there and back it out. Its worth a shot anyway and has a small chance of working.
