2wd Mod or Stock and Buggy or Truck?
I'm looking to try wheeling a two wheeler but not sure where to start, at all. I know the mod class is much faster and generally has the better drivers. As does the buggy class compared to the truck class. I'm going to be racing but wouldn't mind having a semi decent basher. I was looking at the Associated T4.1 brushless RTR. Is there anything else that is comparable or is there a recommendation for something else? As you can see I'm leaning towards truck, but who knows?
I really have no idea what motor or ESC to go with, but based upon what I've read here on the boards, the Tekin RS seems to be the best bet for stock at least, and the RS Pro for Mod.
Stock motor is 13.5T or 17T (?). And mod is unlimited (?).
I currently have a HB Ve8 that I race, granted my driving is quite lacking. I'd like to do some 2wd to improve on the driving skills.
Thanks!
Thanks!
I have a b4 and I ran the stock class (no timing/boost) and it was fun with my 17.5. But I wanted a little more outta my motor so I'm running super stock(13.5). I'm excited to see how is goes. But I ask at my track and kids are running 8.5 for mod class.
Thanks!
Thanks!
I think stock class is pretty fun. Even stock buggy can make you a pretty good driver. Especially in tight indoors
I think for this year in 1/10 we are going to run a superstock class that will allow both unboosted 13.5 and/or boosted 17.5. Based on stuff people already run in this area.
Stock is generally 17.5 and Superstock is 13.5, also depending on your track and area. Ive seen variations.
If you really want to improve skills, 2wd buggy all the way. ST is also loads of fun but more forgiving than buggy.
Between the RS and the pro. The regular RS will still handle a pretty stout motor in 2wd offroad, down to a 5 turn i believe. The RS pro is made to handle some of the power/traction that 4wd onroad can put down. They claim no motor limit.
Either way you cant go wrong with the Tekin, fine product.
If you are going to be replacing motor and ESC and such, you may want to look at the FT kits, they offer a little more and are worth it in the end if you are planning to upgrade stuff anyway.
We are currently running tight indoors clay with a 13.5 limit in both buggy and SCT. The 17.5's are putting down way better laps.
stock buggy can b just as competitive as mod if not more so...and depending on the track actually more controllable and just as fast...but that also depends more on ur driving ability
not at all...i would think about a traxxas sc...either the 4x4 or the 2wd....ALOT more durable for bashing and the occasional trip to the track
Buggies can do some awesome bashing in the right setting. Grab some dirt hawgs for asphalt/general purpose. They last a long time and hook to asphalt/concrete like glue. Wheelies what?
You are somewhat limited in taller grass and really bumpy/rough terrain. But a ST would do almost the same.
Not trying to sway you just my 2¢
R/C Tech Elite Member
I agree, many guys around here run a 13.5 in mod class just because as we all know "slow is fast" but we run 13.5's in stock class around here. I even ran a 13.5 in mod truck class at our big race and had a blast but the mods definately pull on the straights though!
I've decided to go with Stock Stadium Truck. How's the RTR T4.1? Also, the RTR comes with a 3300kv motor, but it's to my understanding that any RTR motor can run in the stock class, is this generally correct? I know it varies from track to track, so generally speaking.
Your thoughts!
Your thoughts!
