Old 02-20-2011, 11:24 AM   #1
Zako51's Avatar
Trader Rating: 20 (100%+)
Default My SC10 will not go in reverse!!!
I just bought the RTR Brushless SC10 and I switched the radio and receiver over to traxxas.
I cant get the car to go into reverse...
Any Suggestions???
Associated Factory Team SC10 | Traxxas Slash 2wd (ProLine Kit, Brushless) | Jammin SCRT10 4x4
SPONSORED BY VISA (AKA...MY CREDIT CARD)
Zako51 is offline   Reply With Quote
Old 02-20-2011, 11:27 AM   #2
Any Suggestions???
Two things... Reprogram your esc to have it and recalibrate your remote with the esc
Tekno EB48.3 Novak Activ8 1900kv
TLR TEN-SCBE 1/10th
Rc10b4 FT Novak GTB 13.5/17.5
Rc18r Mongoose Novak 13.5
SLO county race is offline   Reply With Quote
Old 02-20-2011, 10:22 PM   #3
Who needs reverse?
Murdered 5T is offline   Reply With Quote
Old 02-20-2011, 10:41 PM   #4
goose ae's Avatar
Trader Rating: 19 (100%+)
People like me who can't seem to stay out of the pipe.
R/C Militia Racing.
www.infowars.com
Horsepower is how fast you hit the pipe. Torque is how far you take the pipe with you. The Goose
goose ae is offline   Reply With Quote
Old 02-21-2011, 06:25 AM   #5
lowroad's Avatar
Trader Rating: 79 (100%+)
switch back!
lowroad is offline   Reply With Quote
Old 02-21-2011, 02:43 PM   #6
GizmoJunkie's Avatar
Yeah sounds like you need to recalibrate your esc to the radio, surely the signals/sensitivity is different.
FT B4.1, FT SC10, FT B44; Tekin RS/Savox/D3's
HB D8/D8T - Werks/Buku/Savox
Airtronics
GizmoJunkie is offline   Reply With Quote
Old 04-05-2011, 09:48 AM   #7
i have the same issue. i bought a new sc10 but it will not go in reverse. how would i go about reprogramming my esc for reverse? this may be a stupid question but i have no clue what i am doing
klevelandkid is offline   Reply With Quote
Old 04-05-2011, 12:12 PM   #8
millerman23's Avatar
http://www.youtube.com/watch?v=WvvW6INenqs
This should help
SC10 w/ Sidewinder 5700kv. Still need more traction (almost curred)
RC18 Just for fun
millerman23 is offline   Reply With Quote
Old 04-05-2011, 01:22 PM   #9
thanks for the link. it was helpful to learn what the controls do and how to adjust them. but how do i make it go this thing go in reverse?
Old 04-05-2011, 01:27 PM   #10
http://www.youtube.com/user/TeamAsso...26/9lp-HbRIl5g
Sorry wrong link first time.
RC18 Just for fun
Old 04-05-2011, 01:41 PM   #11
awesome millerman. thank u so much. im about to attempt it as soon as i get home
Old 04-05-2011, 01:44 PM   #12
no problem. subscribe to that channel they seem to be coming out with a bunch of tips and tricks.
RC18 Just for fun
Old 04-06-2011, 06:24 AM   #13
it turns out i have the sc200 which i followed the instructions to reprogram the esc (where you hold down the select button or something like that and wait for the light to flash to set neutral, throttle and reverse). it still wont go in reverse. the wheels stopped spinning, but no reverse action. any suggestions?
Old 04-06-2011, 08:32 AM   #14
Rysuleod's Avatar
http://www.teamassociated.com/pdf/ca....sc200.esc.pdf
From the instructions:
Disable Reverse - With the ESC connected to the battery,
press and hold the set button and switch the ESC on.
Reverse will now be disabled. Follow the same
procedure to enable reverse.
Set-Up Procedure
Before beginning the setup procedure, be sure to set the
transmitter’s throttle and brake EPAs to 100%, set the
throttle trim to neutral, and set the car on a stand so that
the wheels are not touching the ground.
1. Turn on transmitter
2. Plug the battery into the ESC
3. Switch the ESC on
4. Press the SET button for at least 3 seconds using the
plastic screwdriver supplied
5. The LED now flashes red/green to indicate that the
ESC is in setup mode
6. Leave the throttle at neutral and press the SET
button again
7. The neutral setting is now stored and the LED
lights green
8. Move the throttle trigger/stick to full throttle and press
the SET button again
9. The full-throttle setting is now stored, and the
LED lights red
10. Move the brake trigger/stick to the full brake/reverse
and press the SET button
11. The full brake/reverse setting is now stored, and the
LED lights simultaneously 3 times.
12. Then the red/green LED remains on.
Setup is now complete and the ESC is ready to use.
Rysuleod is offline   Reply With Quote
Old 04-06-2011, 09:44 AM   #15
Rick Hohwart's Avatar
If you are using NiMH batteries you should also switch the ESC out of LiPo mode.
Rick Hohwart is offline   Reply With Quote
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 06:57 AM
New Indoor Track in Springfield, IL deweysrc Wisconsin & Illinois Racing 714 01-16-2016 06:59 PM
Novak Havoc Pro SC ESC Thread litlemac26 Electric Off-Road 452 06-04-2014 10:09 PM
slash / sc10 class evoving gweed Electric Off-Road 680 04-29-2009 01:30 PM
