Traxxas Slash Rear Shocks Sit and I cant figure out why???
thats because the slash comes with progressive shock springs which mean at the top of the spring its stiffer and the bottom it is softer .
sounds, like the shock oil is low or the shock bladder is teared or just bad and maybe a rebuild for the orings in the shocks also.
or theres air bubbles in the shock oil inside.
You also could have bent the shock rod. to check for this,take the shock off of the car and move it up and down. if it semms to be getting stuck, my gess would be you bent the rod. Simply remove the shock cap and the small end pice at the end of the shock rod, figure out wich way its bent and use a vice and a small hammer or pliers to bend it back. This problem has happend countless times to my slash. Hope this helps!
or the half shafts are dirty and binding
