Burning Glow Plugs..why? >
Old 08-18-2004, 06:36 PM
Default Burning Glow Plugs..why?
Tonight for some reason I had alot of problems starting my car, it appears I have blown about 4 plugs tonight before I even got the car started?
What could be happening here, the plugs ranged from 6-8 and I finally got to run one tank with the 8 and then that was it?
e420x is offline
Old 08-20-2004, 06:35 PM
Scrad's Avatar
Trader Rating: 16 (100%+)
What are you using to ignite your plugs. You might be putting to many volts to the plug and they melt.
Scrad is offline
Old 08-20-2004, 06:51 PM
JoshR 85's Avatar
HeY!!!
could you possibly be running the motor way to lean or way to rich???
JoshR 85 is offline
Old 08-20-2004, 09:28 PM
ctardi's Avatar
Sounds like way too much voltage. should be using 1.5 ish. Or, 1 single cell battery, such as a size C or D or some guys have even use AA or if they are desperate, AAA
ctardi is offline
