What cell config
What cell config
I'm going to be running a Losi 8ight 2.0 buggy. In terms of run time, and temps what battery config do you rec? 5s or 6s. I'll be running a 1660kv motor that can handle up to 6s.
I know 6s is usually more efficient heat wise and you can use lower mah batteries.
I'll be using this motor
http://hobbyking.com/hobbyking/store...dProduct=15234
more efficient, but only if you use low kv motor. for 1660kv go for 5S
and the motor you plan to run will be hot so be careful with gearing.
