Old 03-27-2011, 01:52 PM   #46
Yes, the holes for the mounting screws are the same distance apart and the Tekno chassis is flat, no turned up edges. The Tekno mudguards are pretty much a straight up design. They don't bow out to the side much.[/QUOTE]
Thanks kufman. good to know, will have to pick up a set.
slimthelineman is offline   Reply With Quote
Old 03-27-2011, 02:33 PM   #47
OSR
OSR's Avatar
Default body fit
will the stock rc8be body fit on the tekno conversion without modification?
Mike McGhee
G's RC Raceway
Don't be a sore LOSER! You'll look like an IDIOT!
NOT EVERYONE GETS A CHANCE TO OWN AND RACE RC CARS....IF YOU DO, YOU SHOULD APPRECIATE IT!
OSR is offline   Reply With Quote
Old 03-27-2011, 02:39 PM   #48
symmetricon's Avatar
Trader Rating: 27 (100%+)
No. The tekno chassis is much narrower.
XRAY / RCAMERICA
JCONCEPTS
RCSHOX
Mikes Hobby Shop
symmetricon is offline   Reply With Quote
Old 03-27-2011, 02:44 PM   #49
kufman's Avatar
No, the Tekno chassis is narrower as said above and the front corners of the chassis are pushed forward compared to the stock chassis.
Brushes? We don't need no stinking brushes!!!
kufman is offline   Reply With Quote
Old 04-08-2011, 07:31 AM   #50
jetbill007's Avatar
Trader Rating: 20 (100%+)
Thumbs up Setup changes based on new chassis
For those who are successfully racing this setup- can you share your info.
Springs/shock oil, wheelbase position , diff oil etc.
Naturally the lengthened chassis will create more on power steering in addition to the improved chassis layout(more forward weight).
The only things I can think about from the start would be to increase front shock oil to 40w (1.3x8 pistons) and 35 in the rear.
Lower front diff oil to 7k with 3k in the rear. Thinking about the rear, maybe soften up to black springs with a thicker 2.8 sway bar.
First time at the track this weekend with this chassis, now if I can get new arms and towers (just like everyone else wants).
Thanks for any feedback.
jetbill007 is offline   Reply With Quote
Old 04-08-2011, 09:13 AM   #51
Ed237's Avatar
What bodies fit the best for the V4 RC8 chassis?
Ed Toth
LCRC Raceway and Bumps & Jumps.
Ed237 is offline   Reply With Quote
Old 04-08-2011, 09:35 AM   #52
R-E-A-P-E-R-'s Avatar
I just got my V4 together. I am not a fan at all of how close the esc sits to the pinion gear. I am going to fabricate a ESC mount that sits where the brake servo would go and mount my esc there. Other than that I like the slimmer profile of the car. I have a Proline Slipstream body on the way. I have always liked that body and from what I have seen its a good fit.
Here are a couple pictures of the rig. Ill post up pictures of the esc mount later this evening.
Serious About Racing........
R-E-A-P-E-R- is offline   Reply With Quote
Old 04-08-2011, 01:42 PM   #53
Here is a picture of just the mount. Its made from 2mm aluminum, I tapped the screw holes on the bottom so it mounts directly to the chassis via the screw holes that were made for the servo. I painted it plack when it was all done.
Tekno Conversions Thread teknorc Electric Off-Road 10250 01-30-2017 02:30 PM
Team Associated RC8Be Thread kaisertrip Electric Off-Road 7463 01-10-2017 01:39 PM
Associated RC8Be(Keep) or HPI Vorza DriftWoof Electric Off-Road 10 10-25-2010 02:19 PM
