Why does my truck seem like it goes ALOT faster in reverse then in forward?
Hey guys,
I just bought a novak Havoc esc/8.5 motor combo from my LHS. I put it in and everything works flawlessly but it seems like when i reverse it goes a hell of alot faster then in forward. The kit was pre-soldered so I didnt do anythig to the wires. Anyone with any info would be greatly appreciated. Thanks,
Chris
Chris
Go into your radio and use the trottle servo reverse and change it that should solve your problem
Super Moderator
Trader Rating: 31 (100%+)
This might work but you might have to re-program the esc.
Ive tried every possible setting in the radio and it doesnt work.
Super Moderator
Go back threw the "set-up" instructions for the esc.....Novak has always been stupid simple to program, set all your EPA's to max and trims to zero, then set esc. Hold set-up button while you turn the esc on, light will blink, let go of button, pull full throttle, hold, light will flash, go to full brake, hold, light will flash, let go...done.
Ok so I reset everything back to factory settings (esc, transmitter) It was still doing it so i reversed the motor per instructions with esc. now that I did that it goes faster in forward.
The problem I am having now is that when I hit the brake it doesnt brake but goes right into reverse. The good thing is that it goes in reverse slower but I have no brake just instant spinning back tires.
Also when i reverse then try to go back to forward it has that one or two second delay that most esc's have but now in the opposite direction because I reversed the motor.
Am I doing something wrong here?
Do you mean use one channel for screwing around in the yard where i need reverse and use the second channel for when i race where i wont need reverse?
ive noticed that with my crawler and the only thing i can think of is that it seems like novak doesnt use the sensor in reverse because my crawler cogs like a mofo in reverse. so if its running sensorless it would acutally be a little more efficent = run faster. i know this some what holds water because my tekins will run faster in dual mode, which is sensored low speed and sensorless high speed, then sensored mode with no timing advance or boost. just my .02
Yes. When I'm at my friends track at his house or I'm in the front yepard I have reverse on (profile 2 I think) and when I go to an actual track I just use profile 1. The one without the reverse. Look on your manual and it should explain everything. Novak does a really good job explaining how to program and change any settings you need.
