buying advice help??
Going to probally buy the xxx sct i have a t4 and i race begineers and i need to move up starting to win most of the nightly races and the problem is there is no truck class i dont want to run with buggys so i looking in to the losi xxx sct cause there usually tons of sc trucks
I am going to put the b4.1 brushless in there its a reedy 3300kv motor and a brushless speedo do u think that is a good fit for it?? or should i buy a ezrun 17.5 motor in there and put it with my speedo
Also how is the durablity i see them at the track they look pretty tough
one last thing going to change the gearing once i get it going to change my spur to a 81 what should i change my pinion to
My shop as both the BND and rtr i going to get the BND one and bind it to my KO controller that should work right??
Thanks for the adice
The reedy 3300 and the rtr Esc are pretty stout so it's a good start. Once you feel like upgrading that I would go with a sensored setup. You will be surprised how much more control you will have. Be sure to read up or ask around about gearing between the two. I found there was a huge difference between them.
Not sure on the BND and the KO. I was under the impression the BND only worked with spectrum radios.
ya i thought about did not want to really buy the rtr dont need the extra controller and i dont have time to build the ft sc10 and the electronics for it. and my dads brother has like 3 xxx t so i have practically three full parts bins cause he does not use them any more.. cause he got xxx sct
XXX SCT is a great platform and comparable to the SC10 performance.
also will a associated spur gear fit or do i have use a losi spur gear
ok so i just got to see? and what if i got a ezrun 17.5 brushless will that work with my stock esc
also i never tried any graphite parts but do they work better i have heard there more fragile and could break easier... does rpm make parts for the sc truck yet
also do the xxx t front bumper work on it no i would guess no but i dont know
this i kinda of a stupid question but how do tell which body comes with the truck
i know am i just weighing out the pros and cons if i want to buy the truck or not
Do u know how u can tell which truck comes with wht body like the rockstar or the bullydog one
