Old 02-01-2011, 01:35 PM   #1
sst4nbr1's Avatar
Send a message via AIM to sst4nbr1
Default Do the Speed Passion speed controlers have a flashing led when in no boost mode
As the descriptions says,, im going to be running a no boost class,, and even if you hook up the programmer it does not tell you what mode you are in???
Viper RC Solutions TEAM DRIVER
Factory team B4.1
Factory team T4.1
HYPER 9E
Tekin Vintage Mid Buggy & Truck
sst4nbr1 is offline   Reply With Quote
Old 02-01-2011, 02:19 PM   #2
I haven't run it in "sportsman" mode, or no boost mode. From what I heard and what I saw in an email when I got some beta software, is that by the ROAR rules the esc has to have an indication that there is no boost being used. With SP, it is a blinking red light, I'm sure other companies have the same thing. Not sure about how the tuning box would ineract though. I'm guessing it would just not have the boost settings, but as far as not being able to see which mode it's in, I don't know. I hope this helps.
ClaytonE is offline   Reply With Quote
Old 02-01-2011, 02:27 PM   #3
Lax Legend's Avatar
Honestly I've never owned a Speed Passion,but i'm assuming thats what it means.
Lax Legend is offline   Reply With Quote
Old 02-01-2011, 02:30 PM   #4
grapejuice's Avatar
Trader Rating: 133 (100%+)
There is a stock no boost firmware available and I would assume it would indicate that it is in that mode since SP is roar approved.
MHOR RC Raceway / 5280 Raceway
grapejuice is offline   Reply With Quote
Old 02-01-2011, 02:49 PM   #5
sst4nbr1's Avatar
thanx guys,, i have the race directors approval to use the box as my proof of no boost,, which i found that it does display you last settings,, just want to be ready,,, cause i have this thing silly fast with a 17.5 no boost!! Be sure to check out the new VIPER motors!
Factory team B4.1
Factory team T4.1
HYPER 9E
Old 02-01-2011, 02:50 PM   #6
Super Moderator
You need the optional LCD programming box, not the LED box that comes with the ESC, to load the no timing firmware. The no timing firmware is “508 no timing” or something close if I remember correctly.
The PC is the best place to confirm the firmware version. But you might be able to see it without, connect the LCD box, turn on the ESC with the RC battery connected, then press OK, the loaded software version will flash briefly, after “connecting esc”. It may not show the full name though.
If loaded correctly the LED in the ESC will flash, which is what tech will look for.
Dave H is offline   Reply With Quote
