Old 01-31-2011, 03:05 PM   #1
Default Hpi cyber 10b owners HELP
I've got this buggy and none of my lipos fit, the slot is really small. Does anyone have this buggy and if so what batt are you running? I've got a orion rocket 4000 2s and a 5300 2s and both are too wide, no chance of runnin a 3s...
stadiumangt is offline   Reply With Quote
Old 01-31-2011, 10:49 PM   #2
I have a cyber 10b and I have ran it on 3s with a Blue Lipo 3000mah 20c. If I remember correctly you should get batteries that are no bigger than 145x50x25mm that is the maximum size that you can squeeze in it.
Hope that helps you out.
Alex
Alexslow1k is offline   Reply With Quote
Old 02-01-2011, 02:54 AM   #3
Lonestar's Avatar
the orion rockets 4000 fit fine in mine. raise the holders a bit with a couple of washers if needed, put the padding foam on the rear to push the pack forward, and slightly file the external plastic shell to ensure the rear shaft doesn't rub the pack and create friction.
Paul
When the flag drops, the BS stops.
The train stops at the train station. The bus stops at the bus station. In my office I have a workstation.
Lonestar is offline   Reply With Quote
Old 02-01-2011, 03:51 PM   #4
hey thanks for the tip.
Any HPI Cyber 10B owners here? TorqueGt Singapore R/C Racers 58 08-14-2013 01:59 AM
Post a pick of your 4WD buggy slash_abuser Electric Off-Road 335 01-10-2011 11:42 PM
