Charging Turnigy Batteries Above 1C
#16
There's no good reason to charge any faster than 1c. Unlike older battery tech, there is no perfromance advantage to higher charge rates. The argument could be made that higher rates are simply faster but how fast do we need to charge? It still has to taper after the voltage tops out.
Higher charge rates are supposed to shorten the cycle life but I haven't seen testing that shows this either way.
#17
#18
+1 The only reason for high C charging is to cut charging time. This seems to have been driven from the plane side of the hobby and their desire to have only a few lipos capable of high C rates allowing the short charging times to keep them flying all day. Hyperion maintains there is no cycle life detriment to charging at high C rates. Thunderpower makes the same claim and they have an even higher charging C rate.
The 1st generation of lipo media had a chart that showed life versus charge rate and there was a significant loss in cycle life as charge rates claimed. This linkage between life and charge rate stems from that data based on that older, original sensitive media. This was also the media that was sensitive enough to cause fires and pretty violent venting. There have been major improvements in the passing years, addition of fire retardent, nano technology, better substrate materials and so on. Whats available today is far superior to that earliest lipo media.
You do have to have a good enough balancer that it can keep up or be utilized in only the CV portion of the charge where its not going to slow charging own. My iCharger lets you select which part of the charge the balancer is active in.
#19
