Making the jump!! I have the TLR tuning kit and am deciding on either a TLR Flex or BCE chasis. I have checked the first post and tried searching but am really looking for a MUST HAVE upgrade list. HD out drives, Chris Pins.......what should be on the list?
Lastly, I have a MMP and a Balistic 4.5 with the tuning rotor. Good starting place or better off going with something different?
Finally got another scte and looking to upgrade some more. Havent posted here or followed this thread in months or so.
What's the "new got to have upgrades" as of today? Once again been out of the game for a while
I have broken one arm in that spot. As far as the bumpers go I keep breaking the piece that connects to. The small piece that holds the front shock towers on. The rear bumper keeps breaking and I'm to the point where I'm not buying another one, I'll just run with it broke. You know with this truck comming from the 8ight line on vehicles you would think they would learn something from them. I picked up my 8ight T 2.0 yesterday and it is way beefier than the miniaturized SCTE version. The SCTE is well built but there are just some wimpy parts on it that make no sense, like the rear bumper. I really don't understand the hex inserts in the diffs.
One of my arms look like that but the crack is between the center and most inner hole. Glued it up and still running it though.
OTHER BRANDS HOPUPS
Jammin Products Light Weight Aluminum Wheel Hex Set (4)
ST Racing Concepts CNC Machined Precision Aluminum Center Bulkhead (Blue)
King Headz CVD Pin Keeper Set (2)
DE Racing Mud Guard Set (TEN-T/SCTE/810)
SNR Graphite Center Plate 3mm
SNR Graphite Front Top Plate 5mm
Full Set of Chris Pins
AKA Racing Enduro Short Course Tires w/Red Insert (Soft) (2)
LOSI HOPUPS
Losi 4mm Carbon Rear Shock Tower
Losi 4mm Carbon Front Shock Tower
Losi Shock Standoff Set (4)
Losi Aluminum Shock Collar Set (2)
Losi Aluminum Shock Top Set (2)
Losi Aluminum Rear Hub Set
Losi Adjustable Front Hinge Pin Holder Set
Losi Adjustable Rear Hinge Pin Holder Set
Losi Front/Rear HD Lightened Outdrive Set (4)
Losi Center HD Lightened Outdrive Set (2)
Losi Front and Rear Shock Spring Set (4) (Gold–Firm) (Ten-T)
Losi Front and Rear Shock Spring Set (4) (Black–Medium) (Ten-T)
Losi Front & Rear Shock Spring Set (4) (Silver/Soft) (Ten-T)
Losi Spur 40T
Losi TEN-SCTE Wheel Set (2)
LOSI SPARE PARTS
Losi Axle Set (2)
Losi Front/Rear CV Driveshafts and Couplers (Ten-T) (2)
Losi Center/Rear Drive Shaft
Losi Center/Front Drive Shaft
Losi Differential Seals w/Gasket & Hardware (Ten-T) (3)
Losi Shock Rebuild Set (Ten-T)
Losi Front & Rear Gearbox Set (Ten-T)
Losi Front Spindles & Carriers (Ten-T)
Losi Rear Suspension Arm Set (Ten-T)
Losi Front Suspension Arm Set (Ten-T)
Tenshock sc411 vs pro 4
Hi guys, I'm getting a new motor for my scte. What is the difference between the tenshock 4000kv sc411 and the pro 4 4000kv? They are both 4000kv, they are both sensored, and they are both 4 pole. The tenshock has a longer can, so the bearings would probably last longer. The only other difference seems to be the price tag. ???
nevermind....
Hey guys, I'm not sure exactly what the part is called, front bumper support bracket maybe, it's a small piece around the top of the front diff housing, in front of the shock tower. anyways, myself and at least 4 other guys had this piece break this weekend and I was wondering if anybody has came up with a more durable replacement for this piece? It's not that big of a deal really, but I don't think you can purchase it separately, it comes with the front bumper set.
Like to know as well . I sold mine a while back and now buying one tonight .
Reminder, neither the 540/3900kv, the 550/5150kv or the 550/4500kv systems ARE ROAR LEGAL!!!!
The systems were really focused at the basher / hobbyist level market to replace and/or upgrade people in the RTR market. With those thoughts in mind, Viper built the motors to be as efficient as possible at a fair price. Unfortunately that required going outside of the ROAR spec's for the motors, but that was never the intent with the system.
Given the durability/performance of the Copperhead, we are finding they are kind of filling a "void" in the racing market for a simple and affordable system for the 4wd SCT class. Where they are and are not allowed to run is up to the people having the races, and I suggest you check with them to determine if they are legal or not to race there.
I am talking about the small piece that bolts flat to the shock tower with 4 screws around the diff housing, and the front bumper braces to it with two screws.
