Spun out rim fix (sc10)
make sure the nuts are tight EVERY time you run it, locktite, new wheel nuts...
buy new wheels
We offer aluminum hex adapters for the sc10 that will prevent this problem. You have to switch over to our protrac wheels when using these to keep the wheel offsets correct.
http://prolineracing.com/performance...heel-adapters/
http://prolineracing.com/performance...t-inboard-hub/
Now you can run protrac wheels front and rear on the SC10!!
i've got 40/50 runs with no problems, just check every 3 runs, fixing is useless
Cheap trackside fix
This happened to me once. I took a sharp knife and cut a deeper channel where the pin used to fit and then trimmed down the outer circumference (spelling?) of that area so that the axel and pin could sit deeper into the wheel and get a tight fit again. The wheel will end up sitting a little closer in, I mean that your rear track will be narrower, but only by 1mm or maybe 1/16 of an inch, not much. I did this track side in a few minutes. It's a free fix and works for me. It's not what a top racer would do, but I'm still using that wheel. Also, I now check the tightness of my wheel nuts a lot more often.
Is there any plan to do this type off thing for 1/10 stadium trucks?
Super Moderator
Trader Rating: 31 (100%+)
FYI if you use the correct amount of shims and crush sleeve in the hub you can crank down on the nut pretty hard without binding the bearings. Axle nuts are cheap compared to the times and money replacing rims AND tires if you can get them off clean..
Change your nuts often!!!
