SC10 front end slop fix
I have only had my FT SC10 for a few weeks now. I noticed there is an obscene amount of slop in the front end, and I was told by everyone that this is normal. I have tried to adjust everything with little to no results.
one of the obvious sources f slop are the front wheel nuts. when tightened all the way, the wheel still has play. I put the wheel on, took an O-ring about the size of a shock O-ring and slid it onto the spindle. then I put the wheel nut on and snugged it just enough so there was no more play, but did not bind the bearings at all. I took 1/2 the slop out of the front end and the wheels spin freely with no binding.
i may get shot of this, but a bit of slop makes the car better drive-able, everyting with no slop is not easy to drive
Shoe Goo the e-clips into place on the front axles, as they develop a bit of side play.
Shock o-ring on a ball stub before you put the ball cup on will take some slop out.
after this is done, there is still plenty of slop, but it does get rid of a good amount. there was just way too much. I just havent driven it yet
