SC10 Foam Tires?
SC10 Foam Tires?
Does anyone know where to get foam tires for the SC10 without need to change anything on the vehicle?
Anything helps,
Thanks.
Anything helps,
Thanks.
No, epic does not make a mounted foam tire for the sc10. It will require the replacement of some of the front end parts including the front axels. Hexes will be needed for the rear.
I've been looking for and working on this process since November. It's gonna end up being a hpi/kyosho crossover.
Super Moderator
Trader Rating: 31 (100%+)
user name "gone banana" makes custom sets cheap I don't know how to search a user name though....try to send him a PM..
Thanks lowroad!
Mark, they are in the Short Course special issue of RC Driver. I was just looking at that article thismorning. I provides the part number for them but is un-existant on the site.
The problem I've found in my search, which again is farther along than yours, is......
Donuts will have to be custom made,
sc10 tires have a "bead". Inner and "ribs" outer
even with a skinner tire and the outer ribs removed you will still need a tire truer, as the glueing on process will not be even
a tire truer (standard) will work on the smaller diameter wheels and tires (buggy/truggy/oval/tc)
so your looking for a custom made donut, glued on to a modified wheel, in need of a tire truer that doesn't exist.
So.....for the last time, your gonna have to do a conversion....
Yeah same with me..
I'm starting to have second thoughts about getting an SC10 now..
