castle link and transponder
1.Hey i was looking to get a castle link is there any difference between the field link and the usb can u do anything different on either or are they all the same cause there the same price pretty much
2. what would be a good transponder thats not to expensive
anybody??
For transponders they are pricey. Go with the Mylaps setup. Here is a link:
http://www.amainhobbies.com/product_...ed-Transponder
go to http://www.hobbymasters.com they have transponders that are around $70 bucks, the are smaller and you can rotate the transponder number if you needed to . they work on all systems, they are AMBrc. I use three of them. at an average of 15-30 dollars cheaper than the comperable ones that's almost a whole nother transponder for the savings. FYI.
Hey Joe....as for the transponder, you may want to wait to shell out the $70 to $90 bones on a AMBrc compliant transponder until after you stop by your local track to make sure they use an AMB system. It would suck to shell out nearly a hundred bucks when what you really need is a $35 iLap transponder.
Field Link works as the adapter on the Castle Link. You can hook an ESC on the computer with Field Link. So if they are the same price for him why would you limit yourself just to a computer.
