noise on accell
noise on accell
i have a sc10 rtr, and i get a whine grind type noise on accell, this has been an on going issue, but i need it to go away. I have made it go away some by moving the pinion in or out a lil bit, and i have tried to change the play between the gears. Transmission was recently rebuilt with ball diff, but the problem was there prior to change. what should i do?????
Try tightening your ball diff up a bit. It should be 1/8 turn backed off from tight. You should be able to do this by pulling the ballcap off and taking out the dogbone. Not sure on the instructions on how clear they were but they were spelled out well in the FT instructions. I took apart my tranny and had that too loose. I had a similar noise...
Hope that helps
Hope that helps
Hope that helps
Hope that helps
R/C Tech Elite Member
How long has it been since the slipper shaft,idler gear, diff gear, spur gear and/or pinion gear have been replaced? I had this same issue with mine, and replaced these parts and now its almost too quiet. If you look at the side profile of the gear, they will look pointy or star like if they are worn, and this will make a lot of noise...My son's SC10 is getting loud right now, and its prob time for replacement of some or all of the above.
