Setting ride height for an SC10
I set my front arms a hair below level and my bones a a hair below level.
I'm not sure where AE measures for their team setup sheets. I made a block cut to exactly some of thier ride ht settings. Slid it under the chassis and it was 4x4 kinda height. Way too high.
Set ride ht. by moving the spring collars up or down, more or less spring preload.
Some cars don't have threaded shock bodies, they use spring preload clips/spacers.
Moving the shocks around changes geometry and that deos a whole lot of things. Side effects may include ride ht, but that's not the purpose of moving the shocks.
Super Moderator
Trader Rating: 31 (100%+)
Rear is right under the tranny case, the part sticking through the hole in the rear plate. Front is right where the chassis starts to widen out, basically right where the 3 screws are for the top plate. This is straight from Chad Due.
