MRP RIPPER MOTOR HELP(A.K.A) THUNDER TIGER PHOENIX ST[[
I WANTED TO KNOW WHAT WOULD BE A GOOD ELECTRIC MOTOR I CAN PUT IN MY MPR RIPPER.STOCK IT COMES WITH A 17T 540 MOTOR.I WANT TO GET MORE SPEED OUT OF IT JUST DONT KNOW WHAT MOTOR WOULD FIT AND BOLT RIGHT UP WITH OUT TEARING THINGS UP.I KNOW BRUSHLESS IS THE WAY TO GO BUT IM JUST LOOKING FOR A CHEAPER WAY TO BUMP IT UP ALITTLE MORE.ANY IDEAS WILL BE HELPFULL.THANKS!!
brushless
i use a traxxas vxl sytem..recomend tuning clutch,,,diff
dewalt
A 4000kv speed passion brush-less system can be had for around sixty five dollars.it isn't that powerful, but If you keep the temps down it should be quite reliable. If you want to keep a brushed motor in it maintenance is key, if you clean your brushes and armature with Crc electrical contact cleaner. and lube your bushings after every run you should get a very long life out of a brushed motor. Breaking in the brushes properly is also very helpful.
