Old 04-19-2002, 06:56 PM   #1
noline's Avatar
Default B3 setup for slippery track
I have a B3 buggy can anyone give me a setup for slippery track.
And what tires and inserts shoud I use. I'm currenty running mod/ buggy
any help would be greatly appreciated.
noline is offline   Reply With Quote
Old 04-20-2002, 10:46 AM   #2
Tech Legend
Wild Cherry's Avatar
Ft shocks ..
Blues springs,
30w with #2 piston,
mount the shock all the way out on shock tower & inside on the bottom of the arm,
short camber link & 2 degree`s of camber
30 degree caster blocks,
1 oz of lead in ft .
arms level
Try mounting the battery all the way back in the battery tray.
rear shocks..
sliver springs
30w & #1 piston
1.5 degree anti-sqat
short camber link( inside hole on hub) & 2 degree`s camber
mount the shock in the middle on the shock tower & outside on the bottom of the arm.
Rear dog bone level
with out knowing what kind of surface you are running on ...
try using losi silver (wide) with 3/4 rear foam insert( try out well worn fts .)
try using losi red taper pins in back bomb 1 foam insert
You sould try spraying your rear taper pins with motor wash & put in plastic bag for 5 minutes... Then grip - um & put back in bag for a while( 1/2 hr) than run -um. Sometimes you will need to break the tires in for a pack or two...
Just grip your fts...
Tell me how you like !!!
Hope this helps...
Wild Cherry is offline   Reply With Quote
Old 04-20-2002, 09:22 PM   #3
noline's Avatar
Thumbs up
Thanks for the help
Old 03-30-2008, 04:41 PM   #4
wd40prerunner's Avatar
Trader Rating: 8 (79%+)
wow this is old
wd40prerunner is offline   Reply With Quote
Old 03-30-2008, 05:29 PM   #5
Super Moderator
tmail55's Avatar
Trader Rating: 61 (100%+)
BUT I used it last year to setup a B3 for kid to finished 3rd overall in a race series at our local track!!!!
Rev. Terrance / Team HOLY Rollers / R/C Tech > R/C Racers 4 Christ
T3T4 Web Service / Petit RC / RC WISH / RCTen.com #WeAreAE
I believe the word of God for what it says, not what people want it to say!
RC10GT2-E, SC5M, RC10T2, Spec-R S2, FX10
tmail55 is offline   Reply With Quote
slippery as freestyles Nitro On-Road 9 06-15-2008 01:46 AM
Slippery When Wet tenpins77 Electric Off-Road 11 08-16-2007 08:01 PM
Slippery Dan = Great buyer! Turbo Joe Buyer/Seller dispute and Feedback discussion forum 0 02-23-2007 10:05 AM
racing on slippery floor makytc4 Electric On-Road 3 09-24-2006 11:25 AM
Slippery track, need setup help. MDL Australian Racing 10 08-23-2005 03:13 AM
SEO by vBSEO 3.5.0
