sc10 shock question
Go to the associated web site and download the ft sc10 manual. That has the best explanation on how to properly set the new shocks.
They'll allways have that air sound to them, unlike sealed bladder 1/8th scale shocks.
Should the shocks have any rebound?
Oops, mine seem to have negative pressure. The shafts recede into the shock body, what am I doing wrong?
shocks
take off bleader screw and push shaft up again, hold shaft tight against the top and put bleeder screw back in. should work better.
Super Moderator
Trader Rating: 31 (100%+)
With the bleeder screw out I cycle the shaft up and down twice, just did it one day on a rebuild and it works for me, pulling air in on the down stroke doesn't hurt because it just pushes back out when you push the piston back up and put the bleeder screw in. Mine suck in about the same 1/8 inch and rebound about the same. I don't think an 1/8 inch is an issue and they work fine this way.
If the piston sucks back in more than the 1/8 inch you have too much oil in the shock. I get very little if any oil out the hole on the second compression but it works for ME. You would think it would be as simple as the manual says but there is and always has been a little "black majic" in getting shocks just the way you want them, all part of the game.
Super Moderator
I can't say how either but I had the very same "suction" issue untill I tried this, and you don't want ALL the air out anyway. They are still an emulsion shock, air/oil mix. Agian it just what works for me, if somebody tries it and it works great if not that's fine too.
I'm bleeding the shocks as per the manual. I'm thinking when I push the shaft all the way into the shock body the piston is protruding thru the oil.
