Pro-Line 1/10 Closed Cell Foams
#16
I was gonna make some for my Hyper 10tt using the 1/8 closed cells. But I guess I will wait. Keep us posted. Definitely gonna get them.
#17
We only have limited quantities right now and would have sold out completely in one day if we went right to distribution. They are available right now direct for those guys who just have to have it. We plan to relase them through distribution as soon as possible, which will probably be early 2011.
#19
#21
Suspended
Matt When Will Production hit for Consumers???
I would love to get a Rear set set for my 2wd Buggy. Also the Fronts. But More to the Rears. I have been using the 2 stages for a while and loving those. I remember back in the day when we were glueing 2 together to make our own
#22
Anyway, the buggy rears are available right now but through Pro-Line only (explanation for why is earlier in the thread). You can order here: http://prolineracing.com/foam/1-10-c...-rear-inserts/
It will likely be January when we release the 4wd front and truck foams. 2wd front is tbd.
#23
Been waiting for these since the word got out....can't wait to get them.
#24
Suspended
Ha ha, yeah, the good old days...
#25
To help offset the cost of shipping, you can do the following on our website:
If you friend us on facebook you can use the code: FB15 to get 15% off.
Otherwise, you can use the code: plten to get 10% off.
#27
Are these more for high bite tracks? We typically run holeshots, indoor clay, little dusty in later heats. I'd say it's medium to high bite depending on the dampness.
#28
Yeah I am not clear either on when exactly these would be better than regular foams. I run on a clay indoor track and depending on moisture can be high to med bite will these help me?
#30
Not sure on Blue groove but I can see them being used on all surfaces unless there is something that requires a really soft foam or a stiffer foam.
