Ballistic 550 in 1/8e buggy?
#47
I seen your other thread about your losi build..Very cool as I just started to get into E 1/8 buggies, and the 1800kv motor I have in it now is SUPER HEAVY (and not to mention the weight of the battery)
I found this on another thread and if the larger name brand companies can produce a lighter E version of an 8th buggy, we could get away with lesser batteries and smaller motors
I believe this is from hobby people. In a class on it's own, it should be fun, but paired against nitro/e buggys I can see durability being a problem. I think dimensionally it's the size of an 1/8 buggy, but looks to be an exaggerated sized 4wd 1/10 (longer arms,chassis and 1/8 buggy wheels)
#48
Less weight would be a revolution for 1/8 brushless buggies. Little motors & lipos also means prices down, so it would increase even more the interest people have in BL. The two BIG weak points of BL are weight and price. One is finally related to the other. If brands manage to offer the intermediate motors that are missing, the market will explode..
What do you think of this setup?
MMP
Ballistic 550 motor in 2700kv
3S lipos
My 808 only weights 2,5kg without electronics.
MMP
3S lipos
#49
Company Representative
We designed the B-A-B 550 program this AM---should be on-line in a week, or so.(I will post an update here.) The price of the customized Ballistic 550 with a special wound stator will be 129.99. Add the tuning rotor for an additional 5.00. Build time is usually 10 (M-F) working days.
#50
Will this motor also be available?
5951
HV Sintered Tuning Rotor with 5mm Shaft
14.0mm
High-voltage racing
Novak sensored brushless motors, such as HV.
Perfect for drivers looking to increase a motor's natural drag braking and torque, and improve its acceleration response. Higher temperature threshold
#51
P/N 5951 has been replaced with this:
Ballistic 550 Tuning Rotor -- 14mm
This is a GREAT idea, exactly what people are looking for..
5951
14.0mm
High-voltage racing
5951
14.0mm
High-voltage racing
#52
I am building a "light" losi 810e as well. I grabbed one of the Novak HV7.5 refub motors from the novak store for $65 just to try it out in the 1/8 buggy on 3s to see how it ran before getting into a buying a fully customized ballistic 550 motor. If the HV motor works out I might grab one of those custom ballistics.
Quick question... would the 14mm tuning rotor work in the HV7.5 motor I bought? Seems like it should.
#53
Sweet! That will be nice.
We still have some RMF HVs in stock---actually, a pretty good deal:
RMF HV High-Voltage Brushless Motors -- 5mm
#54
How much would the 14mm tuning rotor change the kv of the HV7.5 motor. It's rated 3000kv with the stock rotor. How much lower would the kv rating be with the 14mm?
#55
#56
When are we going to see more 4 pole motors from the "big" companies? I think these would be the best of both worlds, torque and efficiency.
#57
Remember, ROAR refused to approve our earliest BL motors because we were the only company making them and "it wouldn't be fair". Same with ROAR approval for our 550 size motors for 4x4 SCTs---wouldn't be fair.
#60
Why do you think ROAR decided that 540 motors were just fine for heavy 4x4 SCTs---because those same mfgs didn't want our 550s allowed. It just wouldn't be fair.
