Old 02-18-2015, 05:11 AM   #21211
Originally Posted by Davidka View Post
The bellcrank system assumes you have 2.0 caster blocks, which match the spindles to arrive at the same width.
Thanks. Was not aware the castor blocks changed.
Should I update the arms to the 2.0 at the same time?
DESC410R
F104 Pro
TLR 22
Slash 4x4 (the kids)
Notoriousjje is offline   Reply With Quote
Old 02-18-2015, 06:54 AM   #21212
Davidka's Avatar
Trader Rating: 69 (100%+)
Not needed. The key difference between the 1.0 and 2.0 arms were moving the bottom shock mount forward a little to clear the steering link. With the bellcranks that is no longer necessary. In fact, many who run the 2.0 mid-motor with bellcranks switch back to the 1.0 arms to gain the 3rd, outer shock hole that the 2.0 arms lost.
Old 02-18-2015, 07:34 AM   #21213
Great! Thanks for the help!
DESC410R
F104 Pro
TLR 22
Old 03-05-2015, 09:58 AM   #21214
pbomstad's Avatar
I did the bellcrank update. Wow made a huge difference in steering stability and consistency.
pbomstad is offline   Reply With Quote
Old 03-06-2015, 09:10 AM   #21215
bedwell1's Avatar
I'm sure its already been covered but what length sensor wire is everyone using in mid-motor config?
bedwell1 is offline   Reply With Quote
Old 03-06-2015, 10:10 AM   #21216
30Tooth's Avatar
the same length I was running RM, so around 70mm.
<=/=> Hephaestos RC "Did a blind man made this?" <=/=>
Check out these URLs for setup help - www.rctech.net/forum/tags/spreadsheet.html
Brands I like - JQRacing, Kyosho, LM Engines, Mugen Seiki, Graupner, Robitronic
www.rctech.net/forum/racing-forum/775876-crmpl-off-road-track.html
30Tooth is offline   Reply With Quote
Old 03-15-2015, 05:00 AM   #21217
Noob here. I want to change out the servo in my losi 22 buggy. It's the RTR version. Do I need to take off the front end? Undo shocks? Wanted to ask before I start taking things apart. Thx
rcnewbie418 is offline   Reply With Quote
Old 03-15-2015, 05:08 AM   #21218
hacker's Avatar
Trader Rating: 127 (100%+)
is there going to be a new 3.0 version soon? with a decent bellcrank as standard?
modified solves a lot of headaches
hacker is offline   Reply With Quote
Old 03-15-2015, 11:47 AM   #21219
Casper's Avatar
Trader Rating: 23 (100%+)
You can typically get the servo out by pulling out the bottom 4 screws that hold the bottom of the servo mounts to the car and then the top two screws that attach the mounts to the front brace. Then you can usually pull the servo out the back and then unscrew it from the arm that attaches the servo to the steering slider.
So you do not need to take the front end apart.
TLR/Losi Team Driver
TLR/Losi | Tekin | Panther | Venom | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22, TLR 22T, TLR 22SCT, TLR 22-4, TLR Ten-SCTE 2.0, 8ight-E 3.0, Losi XXX-SCB, Spektrum DX4R
WWW.CASPER-RC.COM "Upgrade thrust bearings for TLR 22, AE and Kyosho ball diffs."
"Extreme grease for thrust bearings and Metal to Metal contact"
"Premium diff lube for ball differentials"
Casper is offline   Reply With Quote
Old 03-28-2015, 09:23 PM   #21220
Trader Rating: 16 (100%+)
Does anyone make a firmer set of springs for the losi 22 buggy??? Or what length and diameter are they???.....thanks
Mallard is offline   Reply With Quote
Old 03-30-2015, 05:37 PM   #21221
Can someone point me to a place that sells a mid-motor conversion kit for this 1.0 buggy? I already tried eBay. I currently have the rear setup.
Thanks!
derrickt is offline   Reply With Quote
Old 04-02-2015, 05:12 AM   #21222
roberto_1029's Avatar
Send a message via Yahoo to roberto_1029
Thanks!
I don't think you buy the mid motor conversion by itself. You would have to hit the manual and buy all the pieces separately. Your other options is the for sale forum or eBay.
Losi 8ight-E 2.0--Traxxas slash 4x4 Ultimate (Scalpel Build) --TLR SCTE 2.0
TLR 22SCT--TLR 22T --Axial Wraith
roberto_1029 is offline   Reply With Quote
Old 04-02-2015, 05:55 AM   #21223
indy34096's Avatar
I'm going to replace my rear CVD's and drive cups because they are heavily worn/sloppy from the previous owner. What is the best option? MIP, TLR, or others?
Also, a lot of talk about updating the front end to the 2.0 geometry. I don't think I have any experience with the 2.0 and this is my first Losi. What I can say is that for the track I run on, I have more steering than what I need in most situations. Very tight indoor track where traction is plentiful.
I first found the 22 MM incredibly twitchy compared to my race prepped 4.1 FT. If anyone else finds this annoying, do what I was taught at the track by the fast Losi guys. Turn down your exponential on your steering, along with having maybe 80% of servo speed available (if you have something fast like a Savox 1257/58). Made me more consistent, I must say.
Indoor: TLR 22 Mid Motor
Outdoor: B4.1 Factory Team, RC10 Classic
indy34096 is offline   Reply With Quote
Sponsored Links
Tags
losi, tlr
Trains & Lanes On-Road season....Twenty Ten... Kitchen Racing Forum 1150 02-23-2011 05:01 PM
The New Malta Guys Race Chat 10malta Malta R/C Racers 679 11-15-2004 07:19 PM
SEO by vBSEO 3.5.0
